Inventor Forum
Inventor hanging lots after 2012 sp1 install
12 REPLIES 12
Message 1 of 13
stephengibson76
791 Views, 12 Replies
we are finding that inventor hangs lots since installing sp1, especially when starting a new part and also when switching between window tabs, (from one part to another)
I updated an ilogic rule in our template part but it is still happening on one of the machines that has not got the latest template from vault...
this is getting very tedious
Stephen Gibson
View stephen gibson's profile on LinkedIn
12 REPLIES 12
Message 2 of 13
adsloud
in reply to: stephengibson76
Hi Stephen,
Which Graphics Setting are you using? You can find your Graphics Setting from Tools --> Options --> Application Options --> Hardware.
Debbie Lou
Debbie Lou
Sr. QA Engineer for HSM CAM
Message 3 of 13
stephengibson76
in reply to: adsloud
similar spec machines, different graphics driver, same problem
Stephen Gibson
Message 4 of 13
Hi, Stephen
From your attached screenshot, i see your graphics setting is set as Performance mode, can you try to set it to Compatibility mode for double check ?
Kevin Li
SQA Engineer
Autodesk, Inc.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 5 of 13
that seems to have speeded it up, new part opens instantly now...
will let you know how we get on
Stephen Gibson
Message 6 of 13
no, still hanging...  If you switch between tabs it works ok, but then if you work on one for a while and try to switch back it hangs again.  new parts are a lot faster still
Stephen Gibson
Message 7 of 13
same doing stuff like grounding components, this is awful
Stephen Gibson
Message 8 of 13
Hi Stephen,
I tried your scenario in my Inventor2012 and not reproduce the hang problem. below is my hardware configuration:
  Operating System: Win 7 Enterprise Service Pack 1 64 bit
  Processor: Intel(R) Xeon (R) CPU E5630 @2.53GHz
  RAM: 12GB
  Graphics: NVIDIA Quadro FX 580
I suppose the memory is used up when it hangs, you can check it in Task Manager, also check your virtual memory settings in System Properties and how much available space there is on the disk drive where the paging file is located.  Both of these things can cause you to run out of memory space even on a 64 bit OS.
Kevin Li
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
Message 9 of 13
MjDeck
in reply to: KevinLi-Autodesk
Stephen,
 You mentioned an iLogic rule in your first post.  To see if iLogic is involved in the performance problem, you could temporarily unload the iLogic add-in, in Tools -> Add-Ins.  Click on iLogic, uncheck the Load Automatically option, and then exit and re-start Inventor.
Mike Deck
Software Developer
Autodesk, Inc.
Message 10 of 13
stephengibson76
in reply to: MjDeck
no, still hanging loads with ilogic unloaded...  its quite mesmorizing that spinning blue circle
Stephen Gibson
Message 11 of 13
kstate92
Another silly long shot, but hanging on file opening reminds me of when we had some bad shortcuts (lnk files) and paths pointing to non-existent locations, so the program (AutoCAD in our case actually) would vainly search the entire network for a file or location that was no longer available.  But why that would suddenly happen with installing an SP I can't explain - unless something else changed on the network during that brief window.
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Message 12 of 13
stephengibson76
in reply to: kstate92
Well, I uninstalled SP1 and everything is back to normal...  I can only conclude that the SP screwed something up, there must be other people having the same problem???
Is there a hotfix, just for the select other tool?  I got used to it sort of working again with the SP
Stephen Gibson
Message 13 of 13
Stephen,  I ran SP1 for about a week and never experienced any hangups.  My specs are below.  I have, however, uninstalled due to a few issues I found that were too annoying to work around.
http://forums.autodesk.com/t5/Autodesk-Inventor/Inv-2012-SP1-Data-Entry-in-Old-Dialogs/m-p/3140838
http://forums.autodesk.com/t5/Autodesk-Inventor/Workfeatures-Edge-View-Issue-Inv-2012-SP1/m-p/314287...
