We are seeing lot of performance issues with Inventor 2013 SP2, especially when trying to add assembly into assembly.
I am trying to add an assembly (138MB, 780files) into a newly created assembly (new/blank file).
Sometimes it crashes when creating BOM.
Machine details:
Win7 64Bit OS
8GB Ram
i7 – 2640 @ 2.8GHz Processor
NVIDA Quadro 3000M
Thanks - Vishal
Welcome to the forum!
Do you get the Crash Report screen when your Inventor crashes? The best thing you could do would be to send the error report when your system crashes like that. This way someone form Autodesk can look at your issues, and contact you to help you solve it.
Without a lot more information, there's isn't much we can do here. Can you post your system specs, and maybe a short description of the workflow you are using when you see this problem?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for the reply!
Error report was sent when Inventor crashed, did not receive any reply yet.
System specs are already provided.
Inventor goes blank and Not responding when trying to add an assembly in to assembly.
What I have noticed today is copy and Paste of assembly in to assembly takes only few sec, where as placing it takes 15-20mins.
is there any difference doing copy, paste instead of place?
Hi! The behavior you described here does not sound right. Could you share the dataset exhibiting the behavior with us? If yes, I can set up a secure server for you to upload the files. Please send me an email (johnson.shiue@autodesk.com) so I can start the process.
Thanks!
I am not sure if can share the affected dataset, will check internally and update you by email.
On my recent testing i found that it was hardware patterns which was causing the issue,
After deleting the hardware patterns from the assembly, it made huge difference in time took only 2-3 mins to add assembly.
This assembly has lot of hardware patterns.
Bolted Connections?
These do tremendously slow down an assembly. If you need them for your BOM, you could use Level of Detail on your sub-assemblies to suppress the hardware. This would speed up regen time, but still allow you to have the hardware in your BOM.
Chris Benner
Then I recommend using Level of Detail. See my above post.
Chris Benner
Model contains LOD, the Autodesk Team had reproduced the crash based on the dataset that i provided to them.
they had logged a defect in their Issue Tracking System. Related developer and QA are focusing on solving this defect..
