Inventor 2012
Inventor Fusion starts up when panning around a part model in an ipt file. After creating a feature I pan to a new location when suddenly the pan cursor disappears and Inventor Fusion fiires up. I have to wait while IF opens and then casually inserts an alias item of the entire part into the browser. Then I delete this alias part and continue drawing. For a while, I thought that maybe the mouse pointer was reaching thru the Inventor program and clicking on the IF icon on the desktop behind it. I moved the icon to the far upper right corner to eliminate this possiblilty but the problem remains.
Is anyone else having this problem?
Solved by mrattray. Go to Solution.
Using the left mouse button to pan and then right mouse button to select done. IF actually fires up when done is selected. It doesn't happen everytime but happens ocassionaly.
I was able to uncheck the load automaticallly but the load/unload box refuses to uncheck. Fusion Freeform Edit Launcher shows loaded and load/unload box is greyed out. When I click the translators tab and come back to applications, the load/unload box is not greyed out but the box cannot be unchecked. What about IF Change Manager?
The box unchecked and the Fusion Editor Launcher doesn't show loaded. It may take a few days to make sure the problem is gone.
Thanks for the help
