I'm working with Inventor 2015 Pro.
This happens almost every day. I work with Inventor on and off for most of my work day. I find that when I'm away from it (still using the computer) and I return to Inventor and click 'new', it instantly freezes up. The button is highlighted but the entire program is unresponsive and must be ended via task manager.
This doesn't happen every time, but I always happens in the afternoon.
Does this sound like a network or hardware problem on my end, or has anyone else seen this behavior from Inventor.
Solved by joe.sherry. Go to Solution.
Could be a bad User Profile, try logging in with a different User Account, prefferably, one with Admin Priv if you don't already have Admin Priv on your account. If this solves the issue, let me know and I can attach the instructions to reset your User Account. (assuming you are on Windows)
I don't believe that I have seen the problem you describe but I have a few questions and comments (and some speculation).
First, this sounds too regular and repeatable to be a network or a hardware issue.
When you come back to Inventor after working with other applications, is it only when you click "New" that you see the problem, or does it ever happen when you try to do anything else?
I assume the program is unresponsive indefinitely - I would expect a short delay, because while Inventor was inactive its dlls (libraries) will have been swapped out, and they need to come back into memory. But this should be a fairly short time.
When you kill Inventor from Task Manager, there are a few things to check for that would provide a clue. In the "Processes" tab, enable the columns "CPU", "Commit Size" and "GDI Objects". I would be interested whether:
Inventor is using any CPU at all
The Commit Size is either very large (say around 2,000,000 K = 2G) or still growing
If Inventor is not using any CPU and the memory usage is not unusual then it sounds to me like UI events (such as mouse clicks) may not be getting through, for whatever reason.
This might be a longshot, but if it's always the New command, and you happen to be using Box Sync as a backup utility, there is a known issue. If that is the case, here is additional information:
If you think of any other patterns that might help characterize this, please let me know.
Joe
If it turns out that the suggestion to try running with admin privileges helps, please let me know. Ideally, we do not want to require our users to run as admin (for security reasons), and, as far as I know, that should not be necessary.
Joe,
I'm a bit surprised at your estimate of the number of GDI objects consumed by Inventor 2015. I typically see 1500 when Inventor is first started and no file is open, and 4700-5000 with one or more files open. Closing the files does not result in the objects being garbage collected either, this only happens when Inventor is closed. Compared to similar CAD systems Inventor is a GDI hog.
Neil
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thanks for the help so far.
As it turns out, I am running Box Sync and it sounds like others have solved a similar problem by turning off Box Sync when runing Inventor.
I will try that, and report back if the problem persists.
My mistake on the GDI handles - the number I should have given is 10,000. And we have someone working on tracking down GDI leaks currently. And I am told that typically we do not see a noticeable performance slowdown when GDIs are leaked; the problem is that the program crashes if the maximum number is exceeded. If you see something different let me know. Also, if you have a workflow that shows obvious GDI leaking we'd like to hear about it.
Thanks!
Coincidentally we just heard from Box yesterday - they believe they have a potential fix for the conflict which may be available within the next few weeks. The conflict which causes the freezing is with Inventor File New dialog.
-Chris
I was having what I believe may have been the same issue. I talked to the I.T. help here and after trying a few other things, he tried "alt + space + m" then hit one of the arrow keys(this did not matter which one). When he did this it grabbed the templates dialogue box that had somehow popped up outside of my screen and I was able to move the mouse to a viewable location. After that it appeared where it was supposed to going forward.
I hope that works for you
Chaz Heiber
Autodesk inventor 2018
I also ran into this issue with Inventor 2019.4.4., a recent addition was a WD backup drive. I uninstalled WD Discovery (Version: 3.6.163), rebooted and the issue went away. I realize this is an old post, but it is relevant and 3rd parties still seem to affect Inventor.
