Inventor Forum
Inventor freezes before activation with GTX 660
29 REPLIES 29
Message 1 of 30
robm1983
632 Views, 29 Replies
Hi gusy,
I got Inventor Pro 2014 and the GTX 660 card. When I run inventor to activate it, it would freeze.
I had read about a similar problem here, they suggest to "Run with Graphics processor", but I don't have it, when I right-click the icon.
What would you suggest?
Thanks guys.
R
29 REPLIES 29
Message 21 of 30
robm1983
in reply to: sam_m
Sorry for the missunderstanding, both drives are SSD. I disconnected the new 250gb one, formated the 150gb old one, freshly installed Win7-64bit with all the drivers, .NET, Inventor, etc... but still the same - loading screen pops up, loads to 20% and freezes. 😞 if done in safe mode, it simply closes after 20%, without freezing.
Any other ideas? Thanks
Message 22 of 30
robm1983
in reply to: robm1983
I found that in INVPROSA2014ENUAdlm.log
1232    2014/06/24    14:14:54    Reason=Fatal error
1232    2014/06/24    14:14:54    ComputerName=ROBERT-PC
1232    2014/06/24    14:14:54    OS=6.1.7600.
1232    2014/06/24    14:14:54    File=AdlmIntSATSLicense.cpp,Line=474
1232    2014/06/24    14:14:54    VendorID=2 [ADLMACT]
1232    2014/06/24    14:14:54    VendorError=101 [The license cannot be accessed/loaded/opened]
I am using the 3 year studnet licence that I got here for free.
Message 23 of 30
Ray_Feiler
Try using the 250Gb as primary. Worth a shot.
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 24 of 30
blair
in reply to: Ray_Feiler
Sounds like Inventor is/was installed on the non-formatted disc when it was a primary disc. So a number of it's pointers would be pointed to the O/S when it was the primary disc along with other files. Sounds like a conflict. If this was a primary disc before and was not formatted when it was switched, this would be your problem.
Delta Tau Chi ΔΤΧ
Message 25 of 30
robm1983
in reply to: blair
I just formatted the primary SSD, disconnected the secondary and installed fresh windows 7, 64bit. Still the same, freezes when loading.
in the INVPROSA2014ENUAdlm.log file I get this.
when I removed the file
-erase C:\ProgramData\FLEXnet
-erase C:\ProgramData\Autodesk\Adlm
( as suggested here http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012/AutoCAD-2011-crashes-immediately/td-p/2787094/p... )
the loading windows just poped up and disappeared, without freezing. in the log file I get this
5028    2014/06/24    18:21:03    Reason=Fatal error
5028    2014/06/24    18:21:03    ComputerName=ROBERT-PC
5028    2014/06/24    18:21:03    OS=6.1.7600.
5028    2014/06/24    18:21:03    File=AdlmIntLicenseMgr.cpp,Line=447
5028    2014/06/24    18:21:03    VendorID=6 [ADLMPIT]
5028    2014/06/24    18:21:03    VendorError=24 [Unable to locate the Product Information Table File]
5028    2014/06/24    18:21:03    File=AdlmIntLicenseMgr.cpp,Line=448
5028    2014/06/24    18:21:03    AdlmIntError=41 [Product Information Table file is not found]
5028    2014/06/24    18:21:03    File=AdlmIntLicense.cpp,Line=590
5028    2014/06/24    18:21:03    File=AdlmIntLicense.cpp,Line=591
but once reinstalled again, the old freezing continues.
Message 26 of 30
DannyHubbard
The error you are getting "1232    2014/06/24    14:14:54    VendorError=101 [The license cannot be accessed/loaded/opened]" would indicate that your user account cannot write to or update the folder "C:\ProgramData\FlexNet\" or the files in this folder.
Make sure the FLEXnet folder and the data files in the folder are not read-only for some reason, also check the Security or NTFS settings for the FLEXnet folder to make sure you have Full Control of this folder.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 27 of 30
robm1983
in reply to: DannyHubbard
Tried, all permissions seem to be set correctly...
there's also a log file that says
20:28:55 24-06-2014  [P:1212],[T:1496]     EventCode: 20000009, Message: The service is incorrectly configured, reinstall
20:28:55 24-06-2014  [P:1212],[T:1496]     Exception: 59, Module: f0000, Location: 10
Message 28 of 30
DannyHubbard
Those errors appear to be coming from Windows Event Viewer and look to deal with some issues with Adobe software.
Try deleting the INVPROSA2014ENUAdlm.log file then start Inventor again, post the new log file.
During the startup process how far are you getting? Do you get to or past the first Privacy dialog?
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 29 of 30
robm1983
post here keep diappearing. here's what I'm getting now.
4548    2014/06/24    21:08:06    Reason=Fatal error
4548    2014/06/24    21:08:06    ComputerName=ROBERT-PC
4548    2014/06/24    21:08:06    OS=6.1.7600.
4548    2014/06/24    21:08:06    File=AdlmIntLicenseMgr.cpp,Line=447
4548    2014/06/24    21:08:06    VendorID=6 [ADLMPIT]
4548    2014/06/24    21:08:06    VendorError=25 [Error has occured while parsing Product Information Table file]
4548    2014/06/24    21:08:06    File=AdlmIntLicenseMgr.cpp,Line=448
4548    2014/06/24    21:08:06    AdlmIntError=2 [Failed: Internal programming error]
4548    2014/06/24    21:08:06    File=AdlmIntLicense.cpp,Line=590
4548    2014/06/24    21:08:06    File=AdlmIntLicense.cpp,Line=591
Message 30 of 30
robm1983
It launched! Now it takes like 5 minutes to load, but it does! 🙂
5064    2014/06/24    22:11:04    Reason=License install
5064    2014/06/24    22:11:04    ComputerName=ROBERT-PC
5064    2014/06/24    22:11:04    OS=6.1.7600.
5064    2014/06/24    22:11:04    ShortCode=43191GZDAA7XPPC5EY7J4UHUZ498567Z
5064    2014/06/24    22:11:04    LicenseStatus=2.10.0
any ideas how to make it load faster?
