Hi gusy,
I got Inventor Pro 2014 and the GTX 660 card. When I run inventor to activate it, it would freeze.
I had read about a similar problem here, they suggest to "Run with Graphics processor", but I don't have it, when I right-click the icon.
What would you suggest?
Thanks guys.
R
Sorry for the missunderstanding, both drives are SSD. I disconnected the new 250gb one, formated the 150gb old one, freshly installed Win7-64bit with all the drivers, .NET, Inventor, etc... but still the same - loading screen pops up, loads to 20% and freezes. 😞 if done in safe mode, it simply closes after 20%, without freezing.
Any other ideas? Thanks
I found that in INVPROSA2014ENUAdlm.log
1232 2014/06/24 14:14:54 Reason=Fatal error
1232 2014/06/24 14:14:54 ComputerName=ROBERT-PC
1232 2014/06/24 14:14:54 OS=6.1.7600.
1232 2014/06/24 14:14:54 File=AdlmIntSATSLicense.cpp,Line=474
1232 2014/06/24 14:14:54 VendorID=2 [ADLMACT]
1232 2014/06/24 14:14:54 VendorError=101 [The license cannot be accessed/loaded/opened]
I am using the 3 year studnet licence that I got here for free.
Try using the 250Gb as primary. Worth a shot.
I just formatted the primary SSD, disconnected the secondary and installed fresh windows 7, 64bit. Still the same, freezes when loading.
in the INVPROSA2014ENUAdlm.log file I get this.
when I removed the file
-erase C:\ProgramData\FLEXnet
-erase C:\ProgramData\Autodesk\Adlm
( as suggested here http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012/AutoCAD-2011-crashes-immediately/td-p/2787094/p... )
the loading windows just poped up and disappeared, without freezing. in the log file I get this
5028 2014/06/24 18:21:03 Reason=Fatal error
5028 2014/06/24 18:21:03 ComputerName=ROBERT-PC
5028 2014/06/24 18:21:03 OS=6.1.7600.
5028 2014/06/24 18:21:03 File=AdlmIntLicenseMgr.cpp,Line=447
5028 2014/06/24 18:21:03 VendorID=6 [ADLMPIT]
5028 2014/06/24 18:21:03 VendorError=24 [Unable to locate the Product Information Table File]
5028 2014/06/24 18:21:03 File=AdlmIntLicenseMgr.cpp,Line=448
5028 2014/06/24 18:21:03 AdlmIntError=41 [Product Information Table file is not found]
5028 2014/06/24 18:21:03 File=AdlmIntLicense.cpp,Line=590
5028 2014/06/24 18:21:03 File=AdlmIntLicense.cpp,Line=591
but once reinstalled again, the old freezing continues.
The error you are getting "1232 2014/06/24 14:14:54 VendorError=101 [The license cannot be accessed/loaded/opened]" would indicate that your user account cannot write to or update the folder "C:\ProgramData\FlexNet\" or the files in this folder.
Make sure the FLEXnet folder and the data files in the folder are not read-only for some reason, also check the Security or NTFS settings for the FLEXnet folder to make sure you have Full Control of this folder.
Danny
Tried, all permissions seem to be set correctly...
there's also a log file that says
20:28:55 24-06-2014 [P:1212],[T:1496] EventCode: 20000009, Message: The service is incorrectly configured, reinstall
20:28:55 24-06-2014 [P:1212],[T:1496] Exception: 59, Module: f0000, Location: 10
Those errors appear to be coming from Windows Event Viewer and look to deal with some issues with Adobe software.
Try deleting the INVPROSA2014ENUAdlm.log file then start Inventor again, post the new log file.
During the startup process how far are you getting? Do you get to or past the first Privacy dialog?
Danny
post here keep diappearing. here's what I'm getting now.
4548 2014/06/24 21:08:06 Reason=Fatal error
4548 2014/06/24 21:08:06 ComputerName=ROBERT-PC
4548 2014/06/24 21:08:06 OS=6.1.7600.
4548 2014/06/24 21:08:06 File=AdlmIntLicenseMgr.cpp,Line=447
4548 2014/06/24 21:08:06 VendorID=6 [ADLMPIT]
4548 2014/06/24 21:08:06 VendorError=25 [Error has occured while parsing Product Information Table file]
4548 2014/06/24 21:08:06 File=AdlmIntLicenseMgr.cpp,Line=448
4548 2014/06/24 21:08:06 AdlmIntError=2 [Failed: Internal programming error]
4548 2014/06/24 21:08:06 File=AdlmIntLicense.cpp,Line=590
4548 2014/06/24 21:08:06 File=AdlmIntLicense.cpp,Line=591
It launched! Now it takes like 5 minutes to load, but it does! 🙂
5064 2014/06/24 22:11:04 Reason=License install
5064 2014/06/24 22:11:04 ComputerName=ROBERT-PC
5064 2014/06/24 22:11:04 OS=6.1.7600.
5064 2014/06/24 22:11:04 ShortCode=43191GZDAA7XPPC5EY7J4UHUZ498567Z
5064 2014/06/24 22:11:04 LicenseStatus=2.10.0
any ideas how to make it load faster?
