Hello can anyone tell me why I am getting this MINOR diffrence in frame beams distance?
In mathematics those numbers are equivalent.
I tried to download and extract your zip twice, but got an error on extracting?
There might be a logical explanation, but without the files....
Cannot open your ZIP file, I am assuming that was the assembly and part files?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Must be IV 2014. I'm on 2013.
But as JD says, this is well within tolerances of the system.
Anyone else wanna try opening?
Chris Benner
One is the exact decimal place, the Delta X is just a rounded version of it to whatever overall tolerance you have set. Basically what your drawing dimension will show. Just like in your BOM it will only display 3 places by default, even if you calculate to 8.
