style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"DonA" <djanneken@fuse.net>Jesse,
wrote in message
href="news:f15b6f1.1@WebX.maYIadrTaRb">news:f15b6f1.1@WebX.maYIadrTaRb...
We use Inventor considerably (60%) for mold design.
As far as
mold base, and or other pure mechanical features (parts) Inventor is fine.
As far as cavity and core geometry, I think there is much room for
improvement. In order to get cavity and core geometry straight from the 3D
solid (could be an Inventor .ipt, or "step" file, or similar) you must create
a derived part. This is the only (practical) way I know to add the shrink
factor. (Could be done with proper equations in parameters but would take much
work and be error prone... and you may forget to add shrink any particular
feature, particullarly if you make changes later... and in this business
changes are the order of the day)Once you create the derived part you must now
create assemblies (multiple) in which you place the mold component and the
derived part. You then must create another derived part that represents the
mold by "deriving out" the derived part geometry. Each cavity , core feature
will require its own derived component, and maybe its own assembly.
After a while, this starts getting very confusing... keeping tract of
the path from part to derived part to multiple assemblies to multiple derived
cavity core units.
Also you have to be very careful IF you make
changes, as changes, as say to the part, are NOT automatically reflected
(updated) through the other derived components. You must go to each of them
and make sure thay have updated, and or update them (hit the little lightning
bolt). You also must be careful which file you change. For Part changes, you
must change the origional part, not the derived part. For mold changes you
change the origional mold component IF it does not relate to part geometry,
but you must change the derived mold component if the change relates to the
mold features derived from the derived part.
Yes... this all sounds
very confusing, AND IT IS... too easy to make mistakes, and for $40,000.00,
$80,000.00 and so on molds, mistakes are very expensive.
Perhaps the
biggest issue with Invemtor is parting lines. If parting lines are complex,
varied angles and levels, Inventor simple does not have a way (that I know of)
to create the split. For simple, one plane parting lines Inventor works fine.
This is biggest drawback.
I hope ADesk works to improve the mold
design interface, much like they did for welding, and hope they do it soon.
Molding / Mold making is a HUGE market, and a "super" design tool... Inventor
"Could" be "it", could be a very profitible one for ADesk.
Just an
FYI... several mold shops that I know of use MDT, so that market ADesk already
has and can grow as they are weened from MDT to Inventor... BUT, not to happen
untill the interface is improved.
Jesse, hope this helps... (and
ADesk, hope you have read this as well). I would encourage you to "jump in the
water" and give it try. Inventor is a young growing tool, and "down the road"
can (should be) the industry leader. Just get familiar with deriving parts,
and creating "splits" first.
Don A
wrote in message
Also
you have to be very careful IF you make changes, as changes, as say to the
part, are NOT automatically reflected (updated) through the other derived
components. You must go to each of them and make sure thay have updated, and
or update them (hit the little lightning bolt).
wrote in message
As far as
cavity core units.
Perhaps the
Just an
Don A
"DonA" <djanneken@fuse.net>Adesk,
wrote in message
href="news:f15b6f1.7@WebX.maYIadrTaRb">news:f15b6f1.7@WebX.maYIadrTaRb...
I have tried association as well. BUT, I have never (yet) been able to
get a .idw to update "automatically" when changing lets say the "origional"
part.
Lets take a detailed look at my process and perhaps you can
explain where I go wrong and or need improvements and or changes... My
OBJECTIVE is to create a paper drawing of a mold cavity, which I will call
mold-block1.
I start with... "part.ipt"
I then create
"derived-part.ipt"
I then create "mold-block1.ipt"
I then
create "assembly-1.iam" which consists of "mold-block.ipt" and
"derived-part.ipt"
I then create "derived-mold-block1.ipt" from
"assembly-1.iam". I create the "derived-mold-block1.ipt by deriving out the
"derived-part.ipt" portion.
I then create "mold-drawing.idw".
I then place a view of "derived-mold-block1.ipt into the
"mold-drawing.idw"
FINALLY... I now have a detailed drawing of
derived-mold-block1.ipt which is my origional objective (mold-block1). FINE...
no problem, other than its confusing as he _ _. Now the BIG BUT... I make a
change to the origional "part.ipt". What I would "expect" is that after I
update the "part.ipt" file that the view of "derived-mold-block1.ipt, within
the "mold-drawing.idw" file would be automatically updated. BUT IT's NOT.
What I have been doing is to go to the "derived-part.ipt" and hit
lightning bolt, then go to the "assembly-1.iam" and hit lightning bolt, then
go to "derived-mold-block" and hit lightning bolt, then go to the
"mold-drawing.idw" and it will then update.
Heaven help me if I forget
one of the updates along the way.
Now... this is just for one mold
component. Molds may consist of several... 10, 30, perhaps more components.
Try to keep this process straight for that many files, and you will be as
insane as I am getting.
So ADesk... PLEASE make this process MUCH MUCH
more simple.
And... while your at it please improve upon parting
lines.
Thank You and Regards
Don A 🙂
PS sorry
about this extra long reply, if I could make the process (create
"mold-block1") simpler then the post would be
proportional.
