Inventor General Discussion
Member
jscott19
Message 1 of 7 (764 Views)
Inventor for lattice structure design
764 Views, 6 Replies
01-09-2013 05:22 PM
I have been doing the design and shop drawings for lattice structures using AutoCad in 2D.  It works fine but there are a few problems where parts collide in final assembly.  My client suggests Inventor as he thinks it iwll be faster (and thus cheaper) and it would also automatically make shop drawings of each piece.
While I have no doubt it is possible to design and draw a lattice structure in Inventor, would it be efficient or would it be a waste of time compared to another program.  Would 2D AutoCad be more efficient?
I will be very interested in your thoughts on this question.
Thanks.
PaulMunford
Message 2 of 7 (743 Views)
Re: Inventor for lattice structure design
01-09-2013 11:13 PM in reply to: jscott19
I think inventor would be much more efficient. But there is a cost. Inventor is available as an upgrade from AutoCAD so the software isn't to bad (and you get to keep AutoCAD). However you should budget for upgrading your hardware and training.
There is also an investment In time required. Inventor won't 'automatically' create your shop drawings, but if you learn how to set it up right you can certainly produce them quicker and more accurately than with 2D AutoCAD. The main advantage being that the whole thing is parametric, so if you change your model, all your drawings will update.
The 30 day trial is free. Give it a try!
CSO
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Valued Mentor
stephengibson76
Message 3 of 7 (732 Views)
01-10-2013 01:07 AM in reply to: PaulMunford
we build latice structures in inventor, and give the models to engineers to stress.  The best part of a parametric modeller is that when the engineers change everything all we do is update the parameters to suit and provided the model is built well its ready to go.  Things like the welding space between 2 members conecting to a third at a point can be parameterised with formular so they are a minimum of 50mm or 4x wall thickness, whichever is greater.
It is also very useful at visualizing complex joints where 4 or 5 members are hitting the same area
Stephen Gibson
View stephen gibson's profile on LinkedIn
Valued Mentor
mpatchus
Message 4 of 7 (723 Views)
01-10-2013 03:57 AM in reply to: jscott19
We create all of our structures in Inventor.
Bolt holes now line up in the field and everything goes together much more quickly and easily.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Member
jscott19
Message 5 of 7 (471 Views)
10-30-2013 07:22 PM in reply to: jscott19
I know it's been a while but I finally have a copy of Inventor and I'm trying to learn how to use it.  When I get some proficiency, one of my first "projects" will be a small lattice structure.
Thanks for the comments.
JDMather
Message 6 of 7 (452 Views)
10-31-2013 05:56 AM in reply to: jscott19
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
jscott19
Message 7 of 7 (442 Views)
10-31-2013 07:08 AM in reply to: JDMather
JDMather,  I have already downloaded your PDF and have purchased one of Curtis Waguespack's books.  As I go through the book, I look at the relevant part of your PDF.   I find a second explanation often clears up something I didn't understand in the first refence.  I haven't yet used the Autodesk tutorials - perhaps I should look at them along with the other reference material.  It's slow slogging but I'm getting there.
Thanks for your suggestions.
