I have a 3d solid model made in AutoCAD 2007 with a filename example 101-9001_r1. When i open this dwg into inventor 11, i notice that the filename changes to 101-9001_r11. An additional 1 was placed on the filename. Is it possible to open the dwg solid model on inventor and still have the same file name? I know that you can just save as and remove that additional 1 or any no. there. My concern is actually i'm doing it to more than 1000 files. So i think it will help me save a lot of time if i could still retain the filename from the dwg to my inventor. I also notice that my assembly file all created a filename of their own base on the assembly filename, example assembly filename is 10001. So all of the parts change their part name to 10001-1, 10001-2 and so on. This will definitely give me a headache if i try to make the filename same to my dwg to inventor. Please help!
