Inventor Forum
Inventor Feature works?
24 REPLIES 24
Message 1 of 25
Cadmanto
1831 Views, 24 Replies
For those of you that know Solidworks, they had a feature that could create features from dumb solids called featureworks.  Does Inventor have anything similar?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
24 REPLIES 24
Message 2 of 25
jtylerbc
in reply to: Cadmanto
Yes, but it's an add-in, so you'll have to download and install it first.
http://labs.autodesk.com/utilities/feature_recognition/
Message 3 of 25
in reply to: jtylerbc
Yeah, I really wish this was finally part of basic Inventor by now.
Labs has had this feature for a few realeses now and I use it all the time when dealing with vendor files.
Message 4 of 25
Cadmanto
Thanks.  I will try this when I get back to work.
We are using profressional so I am miffed that this ins't included as well.
Have you used it and if so what are your thoughts?
Best Regards,
Scott McFadden
Message 5 of 25
Cadmanto
Jim,
Me too!!!
I used it periodically when I was using Solidworks.  It was good for simple machined type parts.
Forget it on the ergonomic swept type parts.
Best Regards,
Scott McFadden
Message 6 of 25
jtylerbc
My thoughts are that I've never needed it badly enough to be worth the trouble of trying to get IT to install it for me . . .
Message 7 of 25
JDMather
Identical to FeatureWorks.
I never use Automatic in Inventor or SolidWorks.
Use in manual mode and recognize only those features that will actually be edited.
You can multiple select then right click to combine circular or rectangular patterns.
Message 8 of 25
Cadmanto
in reply to: JDMather
Thanks JD.
My question now is I have downloaded it and when I go to the addins list I am not seeing it in the list.
How do I get it into my Inventor session?
I ahve already closed out of inventor and restarted that thinking that would work...Not!!!
Best Regards,
Scott McFadden
Message 9 of 25
Ray_Feiler
I guess no one likes Fusion?
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 10 of 25
JDMather
You must install with anti-virus and UAC turned off.
I had the same problem on of my machines till I turned UAC off.
Message 11 of 25
JDMather
in reply to: Ray_Feiler
Don't need Fusion for this.
Message 12 of 25
Cadmanto
Ok, does that mean I have to uninstall what I currently have loaded then do as you suggested?
Maybe it is a Friday thing, but what is UAC?
Best Regards,
Scott McFadden
Message 13 of 25
Cadmanto
This does not look like it deals with sketches, which is what we are looking to do.
Best Regards,
Scott McFadden
Message 14 of 25
JDMather
More information is needed.
It does build sketches for recongnized features - just like SolidWorks.
Attach your file here.
Ops - I guess you were referring to Fusion rather than Inventor feature recognition.
Message 15 of 25
Cadmanto
JD, I was responding to the fusion statement on how it didn't look like it produced sketches (in fusion)
not Inventor.
I am assuming I have to uninstall what I have and reinstall like you suggested with the antivirus and UAC turned off.
By the way, what does UAC stand for?
Best Regards,
Scott McFadden
Message 16 of 25
Ray_Feiler
Message 17 of 25
Ray_Feiler
Yes, I just tested this out Fusion does not give you sketches but the plug-in for Inventor does. I did not know this until today. Cool plug-in. Smiley Wink
Message 18 of 25
Cadmanto
Thanks Ray.
I am going to try this at home where I feel comforatble shutting off the anti and the UAC (thanks for the explaination).
Here I have to call IT to feel safe about doing so.
Yes, we have some files that it is important to have the sketches for.  Thus the reason Fusion wont work.
Best Regards,
Scott McFadden
Message 19 of 25
Cadmanto
Finally got it to work.
Thank you everyone for your help.
JD, you were right.  It does work like Featureworks.
Best Regards,
Scott McFadden
Message 20 of 25
JDMather
There are a few hidden things in there.
Right Mouse button sometimes gives you these hidden options.
