Inventor Forum
Inventor - Engraving on a sphere
47 REPLIES 47
Message 1 of 48
220610
4713 Views, 47 Replies
I've been looking around and couldn't find a solution. I have a sphere which I'm able to project on a sketch of smaller circles which I'd like to engrave over it's surface, yet I want each of them to be perpendicular to the surface of the sphere in each point. Emboss doesn't do the trick, it just makes the engraving perpendicular to the plane.
Can someone please help?
Thanks!
47 REPLIES 47
Message 21 of 48
JDMather
in reply to: 220610
Solution in this document or attach your file here.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Message 22 of 48
220610
in reply to: JDMather
Ok, it partially worked.
I've tried using "adjust" to correct, and chose the starting point, and while it does "stick" them to the surface, it doesn't "correct" their orientation, which should be perpendicular to the surface.
Here's what I mean.
Message 23 of 48
JDMather
in reply to: 220610
You also have to set the Direction 1 orientation.
But there are other problems - starting with Sketch1 unconstrained.
I recommend going back through your part and constraining the sketches.
No 3D sketch needed and you are not ready for 3D sketches.
I will come back in a bit and walk you through solution.
Message 24 of 48
220610
Ok, I've repaired the unconstrained parts. I've deleted sketch1 as it was obselete.
This is after constraining, and still the same problem occurs.
I'm not sure what you mean by "You also have to set the Direction 1 orientation.", I thought I did.
I'll wait for your reply.
Thanks a lot!
P.S.
Not sure how I got so caught up in this tiny problem, as I already did something (which I believed) more complicated, an Uzi SMG with movement constraints and all.
Message 25 of 48
JDMather
in reply to: 220610
220610 wrote:
P.S.
Unfortunately - I'll wager it was all wrong too.  Time to learn proper Inventor techniques.
BTW - you did not set the Direction 1 Orientation.
Message 26 of 48
JDMather
Before I spend a lot of time on this - are you willing to spend the time? Do you want to learn how to model correctly?
This angle is not manufacturable and because of the way you dimensioned the arcs are not concentric and therefore the wall thickness is not 5cm. (only those two lines are 5cm)
Message 27 of 48
JDMather
Start a new part file.
Set your units to cm if not already set.
Create Sketch1 as shown and attach the file here.
Message 28 of 48
t22e
I'm willing to learn to do it properly, a good foundation is the most important thing.
You probably guessed it already, but I learned the program by myself and on the move, so that's where my faulty methods are from.
I anticipate our difference in time zones will make delays in our correspondance, so I apologize in advance.
Thank you for doing it.
I'll do everything you sent and will send the files back once it's done.
Message 29 of 48
220610
Hmm... logged me before as guest, nevermind, I'll sort it out later.
Ok, so I've done as you said, I think, that's why they're are two files.
One of them is bound to be what you did (I really hope, otherwise I'm in a bigger hole than I imagined).
Thanks again!
Message 30 of 48
kvannj
in reply to: 220610
I think he means that you should make only one sketch (in 2D), make a centerline (not construction), and simply draw a normal line and set the dimension to Ø120. When you set a dimension to a centerline, you get the diameter directly and not the radius.
Message 31 of 48
220610
in reply to: kvannj
I more than certain you're right, but for some reason it doesn't switch the normal line (drawn from the centerline) as a diameter
Message 32 of 48
JDMather
in reply to: 220610
Neither file you attached looks like what I posted in image, so we will take this one step at a time..
Create a new sketch on the XY plane and then create a vertical line from the origin (I turned on the center point so you can see) and dimension it 30mm.  Save and attach the file here.
Message 33 of 48
JDMather
Select the line and then click Centerline in upper right corner of screen (on standard install).
Save and attach your file here.
Message 34 of 48
JDMather
Create a horizontal line from the top of the vertical line.
Then Dimension by selecting the free endpoint of the horizontal line and the Centerline (not endpoint).
Enter 120 as the dimension.  This should result in a diametrial dimsion.
Message 35 of 48
220610
Thanks for the detailed explanation, there's hope for me yet!
Message 36 of 48
JDMather
in reply to: 220610
Edit your sketch and create a Center Point arc.
Click anywhere on the centerline except for endpoint or midpoint to constrain the center of the arc to the centerline.
Then click the origin and then in space for the 3rd point.
Drag the free end of the arc to the end of the horizontal line.
Then R OK. (to Revolve)
Then Shell and select the planar face and enter the shell thickness.
Message 37 of 48
JDMather
Start a new sketch on the XY plane and then hit F7 (I also went into wireframe visual style).
Create the sketch as shown.
curve constrain.pngIf  you constrain the "top" of the hole to the inside curve - be sure to use the outside point rather than the centerline point.  (or you could go all the way out to the planar face.
R - Cut OK (to Revolve Cut).
Message 38 of 48
JDMather
Get lazy - use geometry constraints rather than dimensions.
Create the sketch shown on the XZ plane.
Then do your Extrude Cut (do you really want a planar face on the bottom of this extrude or do you want it curved like the outer face of the part)?  Do you want the sides with no taper angle?
Message 39 of 48
JDMather
I forgot a critical step - go back and edit the sketch for this feature
Project Geometry the outside spherical curve (must be projected before the Revolve Cut).
After exiting the edit sketch - right click on the sketch in the browser and select Visible.
Message 40 of 48
JDMather
Notice also that in all my images I had right click on the Origin Center Point in the browser and turn on it's visibility.
When you do your Curve Driven (Rectangular) Pattern be sure the Start Point is at the origin and be sure, be sure, be sure to set the Orientation to Direction 1.
