As I understand its not possible to convert an inventor 2013 drawing to inventor 2010. So my question is, is it possible to give the client an autocad 2010 version of the drawing scaled 1:1 with the sheet and title block still there?
Inventor files are not backward compatible..
Just "save copy as" the idw to an autocad dwg file.
Then you can open and backsave in autocad if needed.
Can you just give them a PDF or do they need to edit the drawing for you?
They don't need to edit the drawing, but if I missed a dimension that they need, they should be able to open up the drawing and take it form the autocad file. That is why its important to keep the model 1:1 along with the sheet.
Have you tried exporting to .DWF format?
There is a free viewer so they will be able to print it, measure it, turn on/off layers. and they will not edit it.
Luis José Andueza Castro
Ing. Mecánico - Consultor CAD/CAM/CAE/Data Management
www.dimcad3d.com | LinkedIn |
¿Te resultó útil esta publicación? No dudes en darle Me gusta a esta publicación.
¿Tu pregunta fue respondida exitosamente? Entonces haz clic en el botón ACEPTAR SOLUCIÓN.
Saving to autocad will keep the scale of the part 1:1
