Inventor Forum
Inventor Drawing iAssembly View Change using iLogic
0 REPLIES 0
Message 1 of 1
NSBowser
501 Views, 0 Replies
I have an iAssembly which is configured by a form and parametrically controlled from a single base part.
I have a parameter I can access to know which member of the iAssembly should be activated. (NM0 thru NM7)
Is there some iLogic code to change the iAssembly member of the drawing view, which is manually changed with edit view: Drawing View -> Model State -> iAssembly Member?
Can and if so how can i control this property with iLogic?
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
0 REPLIES 0
