Inventor General Discussion
Johnnyjack777
Message 1 of 4 (291 Views)
Inventor Drawing .DWG outputs broken files
291 Views, 3 Replies
02-27-2012 12:06 PM
The basic save, when making an inventor drawing....
Produces a file that is a Black Panel, to Every other program than inventor... (Tried 5 so far, some just fail to open)
REALLY basic thing that is failing... is it really a proprietary file they "called" .dwg?
Or is there some setting I have on?
Either way, thanks for your time,
-Johnny
Best way to show this is open this file in Solidworks.
I tried your attached dwg with AutoCAD 2012, AutoCAD Mechanical 2012 and DWG TrueView 2012. The two views can be shown correctly.
Which programs have you tried?
Employee
jeffrey.sun
Message 2 of 4 (273 Views)
Re: Inventor Drawing .DWG outputs broken files
02-27-2012 05:39 PM in reply to: Johnnyjack777
Jeffrey Sun
SW Engineer
Manufacturing Industry Group
Johnnyjack777
Message 3 of 4 (262 Views)
02-27-2012 08:53 PM in reply to: jeffrey.sun
Irritating... you have to Save as.... save as COPY.... to get the correct formats... they are NOT in export.
I tried Solidworks, Partworks, alibre/libre? Coreldraw.... pretty much all Non-Autodesk products (Whatever was on the computer I was using ; )
(Also, Come-On!  DWG true view is included WITH inventor, and Audocad/Autocad mechanical are basically the same program too...  Yes inventor opens the file inventor created :smileyhappy:
Employee
jeffrey.sun
Message 4 of 4 (252 Views)
02-27-2012 09:25 PM in reply to: Johnnyjack777
Have you tried to save copy as "AutoCAD DWG File (*dwg)"?
Note: The result dwg of the types "AutoCAD DWG File (*dwg)" and "Inventor Drawing File (*.dwg)" are different. In the Save Copy As dialog, the two types are both listed in the "Save as type" combobox.
Jeffrey Sun
SW Engineer
