Inventor Forum
Inventor Doesn't Insert With DWG
4 REPLIES 4
397 Views, 4 Replies
Hello all,
My Inventor professional 2014 doesn't insert any DWG in the Sketch mode. Anyone see something like that?
Thanks!
4 REPLIES 4
jozef.dubaj
please make sure the dwg holds only 2D model.
Greets,
Jozef
Cadmanto
Pedro,
Are you talking about making a sketch within the confines of the drawing?
Can you post an image of what you are describing?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
JDMather
...are you trying to reproduce behavior that worked as you expected in an earlier release of Inventor.
Post example files if possible.
in reply to: JDMather
Hello all,
My problem is when I try to insert a 2D DWG. When I try to insert the window open but doesn't appear anything (see attached).
I clean the regedit but didn't worked.
