Hello all,
My Inventor professional 2014 doesn't insert any DWG in the Sketch mode. Anyone see something like that?
Thanks!
Pedro,
Are you talking about making a sketch within the confines of the drawing?
Can you post an image of what you are describing?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
...are you trying to reproduce behavior that worked as you expected in an earlier release of Inventor.
Post example files if possible.
Hello all,
My problem is when I try to insert a 2D DWG. When I try to insert the window open but doesn't appear anything (see attached).
I clean the regedit but didn't worked.
