I recently downloaded Simulation CFD 2014 Student and it did not install correctly so I tried the following fix and it worked:
For this error try deleting the C:\ProgramData\Autodesk\ADLM folder. If the error continues try the solution link bellow to clear everything for Autodesk applications off your computer then try and reinstall.
When removing entries from the Registry please follow the recommendations and warnings in this Solution. If an applications Installer fails please seek help from someone or use the Windows Installer CleanUp Utility. Manually editing many parts of the Windows Registry will cause more harm than good. In most cases when editing the Registry users just remove a part of a set of entries which parent and/or other keys in place.
For example manual edits can result in the condition where an applications installer complains that it is already installed and there is no listing for it in the Add and Remove Programs or Programs and Features lists. If this happens, first try the Windows Installer CleanUp Utility. It might just list the application. If not ask for help.
Let us know how things work out.
Hello. This type of behavior is usually connected to licensing. If this is a Network licensing type, delete the cascadeinfo.cas file and try again. It should be located here:
C:\ProgramData\Autodesk\Adlm
If this is a standalone install, delete the tsf.data file and retry. It is located here:
C:\ProgramData\FLEXnet
Thank you for taking part in our community!
