I have Windows XP 32Bit with Inventor 2009. Windows recently did a routine update on my computer and it seemed to cause a different program that I have to stop working properly. So I did a system restore to before the update and that fixed that program. In the meantime, doing the system restore messed with Inventor. Now whenever I open inventor, during its start up screen, Windows Installer keeps coming up. It doesn't say what it's installing, it's just there. It opens Windows Installer twice before it actually opens the program. This happens again whenever I get into an assembly environment except that whenever windows installer is done, the program crashes. Working in the part invironment seems to do fine. I have tried letting the windows installer finish and I've tried cancelling all of them when they pop up, but neither seems to make a difference. It always ultimately crashes. Has anyone had or seen this problem or have some advice on what to do. It's important that I get this up and running.
Hi crev64,
You might search for or ask this question on the Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
I hope this helps.
Curtis
Try a repair first, sounds like the better option may be to un-install and re-install.
I have tried both a repair and a full uninstall and reinstall. It didn't change anything.
You may need to use the Un-install tool that is downloadable from the Autodesk web-site.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14893355&linkID=9242018
