Inventor Forum
Inventor crashing when trying to import part
19 REPLIES 19
Message 1 of 20
572 Views, 19 Replies
I have some large files that I get from a customer in the form of .iges. They give me the .iges because they use CATIA. My problem is that when I try to open the .iges file, it will sit there and try to open in Inventor for about 5 mintues and then the program will just end. It doesn't give me any sort of error message before crashing, it just dissapears. I can open the files in Mastercam just fine. I tried to open the file in Mastercam and save it as a .stp. The same thing happened when opening the .stp in Inventor. I tried to change some of the options that are available when opening these files in Inventor and that doesn't seem to help. I need to get these files open in Inventor desperately. Please advise.
19 REPLIES 19
Message 2 of 20
michaeldavis7418
Have you tried to open the native Catia file in Inventor?
Also, try opening the .iges in Autocad and saving it back out ....
Michael Davis
Charlotte, NC
Work ~ Inventor Ultimate 2013 SP1.1
Win 7 64bit ~ i7 20gb
Nvidia Quadro FX 1700
Home ~ Inventor Ultimate 2013 SP1.1
Win 7 64bit i7 - 16gb
Nividia GeForce 9800 GT 1GB
240g Kingston HyperX SSD
Message 3 of 20
in reply to: michaeldavis7418
I did try opening the native CATIA file in inventor. It acts like its going to work but when it's finished loading there isnt anything there. It just ends up opening a blank part and even calls it part1 or whatever number it was on. It doesn't seem to work. I will try opening the .iges in autocad.
Message 4 of 20
michaeldavis7418
can you get them to save you a .Sat ?
Michael Davis
Charlotte, NC
Message 5 of 20
JDMather
I don't see where in this thread you have indicated what version of Inventor you are using.
It sounds like a corrupted install.
Create a simple cube in Inventor.
Save as IGES and as STEP
Can you write out and read back in the files you created?
Have you tried opening in Inventor Fusion?
If you request an ACIS (*.sat) be sure to tell them to set to v7.
My guess is that be better route to success is to find out why your Inventor install is not reading these file types.
Message 6 of 20
michaeldavis7418
in reply to: JDMather
I've seen parts come into Autocad, that would error out in Inventor ....
The file is only as good as it is exported out ... it might have conflict with the options set on the import as well ..
Michael Davis
Charlotte, NC
Message 7 of 20
Autocad won't open it. It doesn't even give .igs as a file type to look for when opening a new file. I tried to click the file and say open with autocad but nothing happens.
I have Inventor 2009.
Message 8 of 20
JDMather
What version of AutoCAD?  Only v2013 will open IGES and STEP.  (or AutoCAD Mechanical)
Did you try writing out simple cube and reading back in as suggested?
Message 9 of 20
I have AutoCAD Mechanical 2009. I created a cube and saved as .igs and .stp. I closed out and came back in and I could open both files.
Message 10 of 20
michaeldavis7418
the command for AutoCad is igesin
Michael Davis
Charlotte, NC
Message 11 of 20
I found how to import it into AutoCAD, which worked. Now how do I get it into Inventor?
Message 12 of 20
Step it out ...and then Step it into Inventor
Michael Davis
Charlotte, NC
Message 13 of 20
I steped it out of AutoCAD, but it didn't come into Inventor. When I steped it out of AutoCAD it took like 1 second for it to convert it and save it, which seems unrealistic. When I opened in Inventor it was just blank.
Maybe a reinstall is a good method to try. I would need some guidance as to how to do that. I have a stand alone version of Inventor that comes with AutoCAD Mechanical. A reinstall would be nice because my content center doesn't work. Its empty when I try to access it.
Message 14 of 20
can you attach the file, and you have to pick it for the step out ....
or you could open the Autocad file directly in Inventor,
but I'd love to see if I can open it ...
Michael Davis
Charlotte, NC
Message 15 of 20
I did select all the lines of the part when I did the step out. It didn't make a difference. Unfortunately I can't attach the part because my customers would not be happy. They are very into confidentiality.
Message 16 of 20
rdyson
Is the original Catia solids, surfaces of mesh? I suspect the latter.
PDSU 2016
Message 17 of 20
in reply to: rdyson
I'm sure that it's surfaces. It's a complex injection molded part.
Message 18 of 20
michaeldavis7418
oh ...didn't know it was surfaces, did you see if you could change the transparent on the file you brought into IV ..
make sure you also have in the options, surfaces' clicked or it might not bring them in ..
Michael Davis
Charlotte, NC
Message 19 of 20
JDMather
in reply to: rdyson
I know you tried some options, but you might read this.
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
I forgot if you were able to step out and in a cube directly in Inventor (no AutoCAD Mechanical, only Inventor).
If this doesn't work there is definately a problem with the Inventor install.
Have you tried Inventor Fusion?  free http://labs.autodesk.com
You might also sign up for the Beta of Fusion 360 (search Google).
Message 20 of 20
rdyson
In the Autocad dwg, select one of the surfaces and type   list   at the command line. What does it report?
PDSU 2016
