Inventor Forum
Inventor crashes when new "norm.ipt"
10 REPLIES 10
Message 1 of 11
1125 Views, 10 Replies
When I want to create a new norm,ipt, inventor crashes, after loading some things (shown in the left below).
Can somebody help me pease? Thanks! Smiley Wink
10 REPLIES 10
Message 2 of 11
blair
Is this a new installation or did this just start happening.
System spec's and IV version help as well.
Delta Tau Chi ΔΤΧ
Message 3 of 11
cbenner
Hello and welcome...
Um,... what?  Norm.ipt?  Do you mean a template?  Your post says shown in the left below... there is no image or file attached.  What version of Inventor?
Message 4 of 11
MariaManuela
Welcome.
Inventor 2014? If yes...The 2014 version came out a little unstable 🙂
Please install as soon as you can the Servce Pack 1 http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019
Asidek Consultant Specialist
www.asidek.es
Message 5 of 11
I have Autodesk Inventror 2014.
It happens since the installation.
As you can see in the Attachment, its a template I want to make.
I downloaded the latest graphic driver (nvidia geforce gtx 660m), but it also did not help, it still happens.
Message 6 of 11
I also installed the service pack 1
Message 7 of 11
blair
When you installed were you logged with with Admin privedges?
UAC slider set to lowest setting, depending on your Anti-Virus, some versions require it to be disabled for the install.
Delta Tau Chi ΔΤΧ
Message 8 of 11
1) Disable Firewall
2) Install Inventor 2014 as administrator
3) Run service pack 1
4) start Inventor -> still the same
Message 9 of 11
blair
Looks like you are trying to open a template file. Possibly there is something wrong with the "Norm.IPT"
Does it work with the "Standard.IPT"
Did you do a complete unistall of Inventor before re-installing?
Delta Tau Chi ΔΤΧ
Message 10 of 11
Curtis_Waguespack
Hi erhardtalex,
In addition to the other suggestions, you might also try to run under the Software mode, in order to rule out graphics issues:
http://inventortrenches.blogspot.com/2011/01/graphics-issues-application-options.html
I hope this helps.
Curtis
Message 11 of 11
JDMather
in reply to: blair
I suspect Norm is simply a translation of Standard.
Clean uninstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
