I am looking to buy a desktop computer for college. Something that can run Inventor and Solidworks.
My budget is a little of over $3000.
I have looked into buying the "Dell Precision T7610 Workstation"
http://www.dell.com/us/business/p/precision-t7610-workstation/pd
My concern is that, would I be able to build a better computer for around the same price. What do you guys recommend/think?
Also I had another random question, If I bought a cheap laptop and had my powerful machine. Would I be able to Remote Access the powerful machine from my laptop and use Inventor/Solidworks with out too much of a struggle.
Matthew
Look at a good fast "gamming" computer. Inventor a number of years ago switched from OpenGL graphics system to Direct-X. This no longer requires expensive "Quadro" graphics cards, a good fast "gamming" card will do. Solidworks, the last time I checked still requires OpenGL which requires a graphics card (hope I'm proved wrong).
I would bet that a good "gamming" laptop like an AlienWare Mx18 would work fine for both applications and you would still have money to spare over a Dell Precision.
I believe SW is OpenGL, so it will more far more fussy about graphics cards than Inventor.
As mentioned, Inventor should be happy with a gaming spec pc, so a GeForce would be fine (I would recommend a GTX 670 or higher) but Solidworks may well need a Quadro if it is still OpenGL... It might work with a gaming pc, but it might not be 100% happy...
It's a great move by Autodesk which is rarely touted as it means the hardware costs are considerably cheaper 😉
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
In general you can always build a cheaper/better computer than buying a preconfigured Dell workstation..
I really like cyberpowerpc.com
Its where I've gotten my last 2 computers (before that was an HP "workstation" that was nothing but problems)
