Inventor Forum
Inventor change default normal
1 REPLY 1
ipburbank
270 Views, 1 Reply
When placing a transitional constraint to a surface (the part has no volume) the default normal is inconveniently on the wrong side of the face. Is there an easy way to change the default normal for future constraints? (92 objects have this constraint applied to themselves and the surface).
Istvan.
1 REPLY 1
SBix26
in reply to: ipburbank
I can't see any way to change this, and I can see how it would be quite tedious if you have many such constraints to place.  Select Other allows you to select the other normal of a surface, but that's a lot of extra clicks to do the job.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
