Hi everibody!
I downloaded inventor professional 2014 3 months ago and everything worked fine. Then I updated to Windows 8.1 and the program stopped working because of error 0xc0000142. I also installed SP1 to solve this problem. However i can't start Inventor because i receive a error report ('a software probem has caused autodes inventor to close unexpctedly') every time i try to start it, few seconds after i click on the icon, when the program is loading. I reinstalled Inventor 4 times but i always have the same problem, and now i don't know what to do...
Try this:
Register Inventor:
1) Press [Windows] key to open Windows' start page
2) Type "cmd" to find "Command Prompt" > right mouse click on it > select "Run as administrator"
3) On "Administrator: Command Prompt" window, type cd "c:\program files\autodesk\Inventor 2014\bin" > Enter
4) Type inventor /install > Enter
5) Wait for 1 min (inventor will be executed background then exit silently)
I'm also having this exact issue. Windows 8.1. Here is what I did:
1. I was using the trial version of the AutoDesk Product Design Suite 2014 (the trial happens to be the Ultimate Version) until it ran out.
2. I bought the sub for AutoDesk Product Design Suite 2014 standard version.
3. I had to uninstall the Ultimate version and install Standard version.
4. I ended up getting the 0xc0000142 error after installation finished.
5. I got Inventor 2014 sp1 and installed fine.
6. Opened inventor and logged in with my user id and pw.
7. Immediately got the error "A software problem has caused Autodesk Inventor to close unexpectedly"
8. Found that there is an update for SP1 and installed it. Same error on Inventor startup.
9. Tried the cmd prompt fix again. Same error on Inventor startup.
10. Restarted computer. Same error.
10. Uninstalled everything and reinstalled Inventor and content center only. Got SP1 again, did the cmd prompt. Same error (it didn't ask me to log in though).
11. Got the update for SP1. Same error.
12. Started up in safe mode, diagnostic mode, ran as administrator. Same error.
I'm at a loss here, everything was working perfectly with the Trial and now I can't even start up Inventor...
I'm in the middle of downloading and installing the trial version on my secondary laptop so I can at least get some work done while I get this resolved.
Please help!
I installed the Update #2 for SP1 which includes the Update #1 changes. I also did the cmd prompt as you described. Still getting the same error.
In safe mode, I'm not connected to the internet and I don't get the error, I just get the "Initializing" screen and then nothing happens.
Out of safe mode I disabled my antivirus and still get the same error.
Any other suggestions would be welcome.
Windows 8.1 64 bit, 2.3Ghz Intel Core i7, 16GB RAM, 1TB HD. Attached is the dump file from the error. Maybe that will give you some insight.
So I created a new user account on my computer. When I started up Inventor, I didn't get the error but instead, got the log in screen like I had gotten the first time I ran Inventor on my normal account. I put in my information and Immediately the program crashed and is having the same error...
Could this be a connection problem? Maybe it is failing to connect to the server that checks my subscription credentials and causing it to crash?
Win 8.1 seems to cause network WiFi issue problems which might be causing authorization/registration issues.
http://www.tomshardware.com/news/windows-8.1-wireless-networking-ipconfig,25555.html
