i like to place a fillet radius of .125 at the bottom of the triangular cut to simulate a ball end mill. Mr. Inventor2014 says it is too complicated to do.
how to get around? thanks.
Solved by dho. Go to Solution.
I can do it (in Inventor) but first thing I noticed is that none of your sketches are constrained.
I didn't bother to go any further.
clearly a PICNIC problem 😉
Hi dho,
You're getting some rough feedback based on how you presented your question. But you're also getting some good advice in that you should always create sketches to be fully constrained. Often if we do not properly constrain and dimension a sketch, non-tangent points in the sketch will cause placed feature, such as fillets, to fail.
I would encourage you to spend some time tidying up your model and if you still think you've found a limitation, resubmit it, and I'm sure someone will offer some help.
I hope this helps.
Curtis
I think I would model significantly differently.
Does this part already exist in physical form?
If so, do you have a picture of actual part?
I don't think I would model the part like this in SolidWorks or in Inventor.
Like this?
added all the dimensions i could. INV accepts >.155r fillet skipping at the corners.
thanks.
I superimposed your part in clear yellow overtop of one of the images to try to get a better idea of the design intent.
I think I can figure it out based on your dimensions, but it would be easier if your picture was better with less parallax error.
Also take the picture against a constrasting color like bright green or magenta or cyan or at least a white sheet of paper. A gray part against gray background is harder to see.
Here is my go. It took about 20 mins. I think i got the fillets where you want them. but that corner between the face, the loft and pocket will always be problematic because there is a complex curve between the pocket and the face... it dips down.
i do get some intresting results if i shell it, does anyone else get the 'stickie out bit' on the inside left hand side.
Its V14.
Hmm. As told before by other members, it seems to be too complicated. I think, it could be done easier.
But as it is, I'd do it like this.
Walter
Walter Holzwarth
My take from looking at the pictures, and yes, you should constrain everything and maybe find a way to show a bit more design intent as it is it looks really random.
BTW does anyone else think that part looks ´´overmanufactured´´ if that term makes any sense. there´s no way that all those details are necessary, or maybe they are?
Also, to claim it´s Inventor´s fault you should be able to model it in another software correctly.
the way i presented my question is questionable. i am in no way blaming inventor. the subject line was trying to catch eyes and give compliment to anyone helping me. seems it backfired.
i am new to inventor, have not went thru any training. the best i got was half hour from the inventor sales person and couple video clips online.
this is an existing part in the stock room. i thought it might be a challenge for me to model it.
here now, i got couple .ipt. i shall go over them and learn something.
thanks to all.
This part is actually a good challenge (I am not satisfied with any of the "solutions" posted here).
I keep a collection of files like this that will make it into a book (if I ever find time to write it).
Thanks for posting it.
I don't have time to work out a "final solution" but it is going to involve the seldom used Intersect option of at least one feature and probably two. I think the method I will end up using might be quite surprising, involving a couple of real tricks.
first, i shall thank everyone who tried to help me.
got hints from all the iptS, i moved extrusion8 after triangular extrusion9 (cut). inventor processed without an issue.
also i got response from INV sales/support (43-1065-01-support.ipt). here is his approach. but seems it did not represent truly the lower left ball end mill cut per 2D drawing.
"because you created the profile first in the pocket Extrusion with 0.125 R corners. When INV tried to blend these corners it was mathematically unable (remember 0.125 may not exactly equal 0.125 - 0.125000001 <> 0.12499999. The larger radius worked because it would skip over the corners where it was unable. the correct approach is to create the pocket with sharp corners and then fillet edges including the verticals. See attached."
the actual part does seem missing the ball end mill "turning" at the lower left corner which most models here omitted.
here is my try (43-1065-01-B.ipt), no deviation taken from 2D drawing even it had "logical" error which caused all the "fuss".
thanks again to all.
@dho wrote:if you can share with me your ipt.
thanks.
I deleted my file, but all I did was extrude your profile as a solid body, fillet the bottom, and then boolean cut the part with the new solid. It will also work if you extrude your profile as a surface, patch the bottom, stitch, fillet, and then sculpt it out. It's been a few days but I think I also extended your profile outside the part so it would cut clean thru to the outside. I can redo the file but it's easy enough for you to try on your own if you're interested in that method.
