My company has just start using Inventor 2013 and Autocad electrical, and we are now trying to develop some wire harness using inventor and autocad electrical. I have one question as how to properly model this in Inventor. I have a 3 position rocker switch that has 6 connection terminals on the back for wire connection. In order to attach the the wire to the rocker switch a push on spade connector is required to be attached to the wire, and then pushed on the terminal of the rocker switch after the switch is installed on our product. What is the correct way to model this in inventor so that I can have a accurate diagram created in autocad electrical. Should I attach the wire to the spade connector or to the rocker switch?
"Typically" The spade terminal is modeled up in Inventor and then a wire harness "pin" feature is applied to the barrel of the terminal to use as an attachment point for the wire. The terminal will be part of the harness and should be dropped into the harness node during initial placement. The pin should be given a name corresponding to autocad electrical.
Now I can't help much with autocad electrical and transfering from one to another as I don't use electrical for any of my harnesses. I plan to start looking into it soon now that electrical is included.
There should be a few (not many though) tutorials floating around.
start here.. hopefully the help files don't go offline again..
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13653850&linkID=9242016
http://www.youtube.com/watch?v=_CTpjdZ_du4
http://www.youtube.com/watch?v=6R0b9_BEZ-I
And I'm fairly sure there was a decent (quickie) webcast here showing electrical to inventor.. Just have to sign up
http://www.imaginit.com/knowledge-resources/webcast-archive
Thank you for you response, I am just looking for what is standard practice for doing these type of connection, as I am new to creating wire harness and not sure if I should attach the wire to the rocker switch itself and use a virtual part to specify the spade connector, or to use the spade connector as the actual terminating point for the wire.
Like anything with Inventor you should attempt to do it exactly like its done in the real world. (which would be to attach the wire directly to the spade connector)..
Sorry I know this is an old thread, but I think I have a similar question. I have a simple harness with wires running from Mil Spec connector pins to a barrier block, terminated with spader connectors. I currently have it modeled with the wires running to a "pin" in the barrel of the spade connectors. The trouble with this method is there is no connectivity between the wire and the "spade" portion which is connected to the barrier block. Is there any way to share connectivity between points on a connector withtout a wire? It seems to me that this is a weakness in the Cable and Harness package.
What do you mean by "no connectivity".. ?
Did you drag/drop the "spade connectors" into the harness node..same with the MIL spec connector?
This is how I would "typically" do a simple harness like that.
First I will drop the MIL connector into the assembly and constrain it where it should be.. Then I would drop each of the spade connectors into the assembly and constrain them.. Then I would create my harness then finish it before I do any wiring.. Then I drag/drop all connectors into the harness file thats created so they are components of that harness. Then I edit the harness and create all the wiring as needed. (see attached file).. part 0300291004 and 7501030431 are the 2 connectors on each end of the simple harness..notice how they are in the harness node and not separate items
And yes there are quite a few "weaknesses" in the cable/harness package.. IMO it needs a total revamp. It hasn't been updated in YEARS.
Thanks a bunch for the help! I am not entirely sure it solves my problem though. What I mean by "no connectivity" is that when I create a diagram or "nailboard" I don't know how to show that the spade connectors are connected to the barrier block without phisically running the wire to the terminal block rather than the pin I defined in the barrel of the spade connector (see attached image). I would like to be able to define electrical conductivity between the spade and the terminal block without having to run a wire. I suppose I could make the entire terminal block with spades one part, but then I would not have a complete BOM. Am I missing something here??
I did not drag and drop the spade and Mil connectors into the harness assembly, just connected up the wires within the Harness envrionment. Actually I am not quite sure how to do that. If I try to drag the connectors into the harness in the model pain it just skips them down below the harness node. I did assign the RefDes's within the harness though, and they are recognized as conectors that can be placeed in the nailboard (the mil spec's are anyway. not the terminal block because I don't have wires phyiscally connected to the pins on the block, hence my frustration). I will try and re-model it the way you suggest and see if that helps.
I have this exact same issue. I'm not sure if I'm just trying to pound a square peg in a round hole, or if I'm missing something. Here is generally the situation:
None of this is ideal. Either you give up a comprehensive BOM on the inventor side by simplifying your assemblies, or you have a complicated drawing on the autocad side.
I think there needs to be a way to link schematic components to inventor assemblies, or associate unique terminals with a parent symbol in autocad.
