Hi Guys,
I am not finding the cable and harness option in my inventor ribbon i am in the assembly mode.
Refer below image.
Can anyone suggest how can i get the option. That would be of great help.
Solved by DarrenP. Go to Solution.
Solved by mcgyvr. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Hi! It should be in Environment tab. If you still don't see it, could you take a snapshot of the dialog (Tools -> Add-Ins). I would like to see if the Add-In is properly loaded.
Thanks!
hi johnson,
as suggested by you i checked in the environment tab but could not find it. refer below image.
Please refer the below image for the tools - addin
Hi! Just based on the Add-In Manager image, I don't think you have Inventor Professional (contains Cable and Harness) installed on your machine. It looks like you have regular Inventor (does not contain C&H) installed. Could you go to Help -> About and check the exact product name?
Thanks!
Thanks!
Yep sure looks like they just have regular Inventor and not pro.. The pro addin list is at least twice that size.
i have to agree
you are probably running Inventor and not Inventor Pro which has this feature
DarrenP
yes you are right, i have autodesk inventor which is not pro.
i checked with the other computer with autodesk pro the option is available in the environment tab.
Thank You for the response.
