I am working on cable & Harness environment in inventor interlinking Acad electrical.
this is regarding terminal block. Which is a 1 pin(pin acts like a node) item in Electrical circuit diagram but this will have 2 pins which are shorted in the physical model. So if I am creating a harness assy by importing this Acad electrical circuit diagram to inventor, it is taking connection from only pin1. But if I want to have connection from both the pins what should i do?
Regards
Chenchu
