I am having a problem in the weldment environment with inventor 2011.
In 2010 i could do just about everything i wanted, and it always worked perfectly, but now in 2011 we have on 3 computers and 2 models a problem, so this is not a problem for one machine or model.
Ok so whats up,
When i make certain preparations, such as move face or chamfers in the weldment assembly, the fillet welds i have allready made give the an error. It sais " Weld compute failed due to a modelling error" and " The weldbead operation did not produce a meaningfull result" . This while i'm doing nothing wrong, or different than i did in 2010.
If i accept this it's immediately impossible to save the assembly. Also after accepting it's not possible to place fillet welds in any assembly at all, doesn't matter how simple i make it.
Please help me out, or we have to consider to stop using the weldment environment, which would be a really big pity. Because it did work well. Now with our new project going back to 2010 is not an option unfortunately.
BTW
We use inventor 64 bit
Greetings,
Ruud Bakker.
Netherlands.
Hi Could you provide the example to reproduce the behavior? This issue looks like geometry specific. There might be a way to make it work but I need to see the files. Feel free to post it here or share it at A360 (my account: johnsonshiue) or any cloud drive of your choice or send it to me directly (johnson.shiue@autodesk.com).
Many thanks!
