I have an Inventor sheet metal part. The flat pattern does not show bend lines in the part file (they show up in the related drawing). This only happens with this particular part file. Any suggestions? File is attached. Thank you!
Solved by JDMather. Go to Solution.
I deleted the Flat Pattern and then re-created it and the bend lines appeared.
Have you installed the Service Pack and Updates?
