Inventor Forum
Inventor Bend Lines not showing on flat pattern in part file
2 REPLIES 2
slimeboy
1189 Views, 2 Replies
I have an Inventor sheet metal part. The flat pattern does not show bend lines in the part file (they show up in the related drawing). This only happens with this particular part file. Any suggestions? File is attached. Thank you!
2 REPLIES 2
JDMather
in reply to: slimeboy
I deleted the Flat Pattern and then re-created it and the bend lines appeared.
Have you installed the Service Pack and Updates?
slimeboy
in reply to: JDMather
Thank you JD! That did it allright. Obviously some kind of bug/glitch. I will download the service packs!
