hi,
I want to install inventor (2012) and solidworks (2011) in the same computer. each software will be used for different job
Is there any issue I need to be aware of?
thanks a lot
Solved by JDMather. Go to Solution.
Why would there be an issue?
I have run Inventor, SolidWorks and Pro/E side-by-side for years. The only problem I see is Inventor is increadibly slow to boot or resume from Sleep mode compared to the other two. Once running though it is fine.
Sir, can you please advise me the method for installing Autodesk Inventor Pro 2023 and SOLIDWORKS 2023 in same computer?
Anticipating a remedial solution.
Best regards
Joy
I don’t know what this means?
What do you need to remedy?
You install Inventor and SOLIDWORKS just like you install any other Windows OS software.
Exactly what issue are you experiencing?
