Inventor Forum
Inventor and Inventor Fusion?
3 REPLIES 3
jz4all
1100 Views, 3 Replies
Hi
Short time ago I got update to my AutoCAD from 2010 to 2013. I got within the paket (Inventor fusion).
I did never use Inventor. I would like to know what is the difference between Inventor and Inventor Fusion?
Can somebody explain that to me or give me a link where I can find the good answer?
thanks
3 REPLIES 3
JDMather
in reply to: jz4all
Fusion is free http://labs.autodesk.com and yet apparently nobody uses it (as evidenced by the lack of responses to your post here http://forums.autodesk.com/t5/Inventor-Fusion/what-is-the-difference-between-Inventor-and-Inventor-F...).
Inventor is an expensive, professional program http://store.autodesk.com/store/adskus/en_US/pd/ThemeID.23155600/Autodesk_Inventor_Professional_2013...
as evidenced by the number of posts in this forum in the same time period since you Fusion forum posts there are significantly more people willing to pay to learn and use Autodesk Inventor.
You can see Fusion demonstrations here http://au.autodesk.com/?nd=classes&filter_keywords=&chunk=15&filter_material=&filter_personal=&filte...
Now I'm sure someone from Autodesk will come along and explain the difference between history-based parametric modelers and direct modelers..... ....just the facts.
jz4all
in reply to: JDMather
Thanks a lot Smiley Happy
john.laidler
in reply to: jz4all
http://labs.autodesk.com/technologies/fusion/
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
