Have you seen all the posts about Norton AntiVirus Try disabling it if you have it.
This is a post from John Elliot
There is one known problem that will cause Inventor to run REAL SLOW.
- Windows XP
- International version of Inventor R6
- Corporate version of Norton anti-virus V 7.61.935 with file checking
enabled.
This causes the task, winlogon, to start gobbling up all free CPU cycles as
soon as Inventor starts.
Workaround: disable file checking or upgrade to a newer version of Norton.
This is documented in the readme.
John Elliott - Autodesk QA
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Walter" wrote in message
news:C12FDC664110EB8D498C28BE16085268@in.WebX.maYIadrTaRb...
> Ok has anybody out there got the same problem as I? After starting Inventor
> the process winlogon.exe spikes my cpu, every 5 seconds or so, up to about
> 55% then drops to nothing again, and then repeats. This 'process' repeats
> (pun intended) even after shutting down Inventor. The only solution I have
> found is to reboot.
> Very frustrating!
