Inventor Forum
Inventor 6 Getting Started Workbook
2 REPLIES 2
220 Views, 2 Replies
I can not find the correct files for Chapter 6 of this workbook. I need the correct file IV6_E06_05.IAM the CD that came with Inventor has the wrong file.
Anyone else having this problem?
2 REPLIES 2
Hello "Grest",
After seeing this posting, I put on my "Columbo"
overcoat and investigated this exercise and the associated assembly and part
files with a more technical eye.  My findings were that the exercise
and exercise files appear to be working as
described.  May I suggest
 the
following:
1) Make sure you follow the steps exactly as
described.  Immediately after creating a new presentation
face=Arial size=2> file, and then using the Create View tool to open the
assembly
file, you are asked to select
the
"Internal Components" design view.
This design view turns the visibility of the two outer components (cylinder and
cylinder head) off, leaving the internal components visible.  If you do not
use
this design view, the assembly may
appear as the wrong file.
2) Make sure the active project is:
Getting_Started_Exercises as described in the Introduction
section of the Getting Started Exercises. If this is not the active
project, you
may not have access to the
"Internal Components" design view after selecting the assembly
file.
Cheers,
RodneyK
Mechanical Training Development and QA
Manager
I
I'll try it again.
