Drawings views from the 4 stages of a weldment (Assembly, Preperation, Weld, Machining) show correctly in Update 1 (see attached screenshots) but do not work when Update 2 is applied (again, see screenshots)
Uninstalling Update 2 (revert to Update 1) fixes views (change from one stage to another, then back to the desired stage)
Regards
MattH
Hi! I am sorry that I cannot seem to reproduce the behavior on my machine. Could you post the example here or send it to me directly (johnson.shiue@autodesk.com)?
Many thanks!
