Solved by ChrisMitchell01. Go to Solution.
Yes, there are some of us having this issue. Move your design data to a local path rather than on the netework.
Is that any better?
Right now all you can do is to ensure that the Inventor.adsklib file under ..\Design Data\Materials folder is on a local disk & switch to using Bounding Box for your view previews (from Tools Application Options, Drawing tab).
A fix for this is in process for potential inclusion in SP1 Update1, (early November).
Chris
Thank you. lets hope you guys get it sorted. Cant get any work done right now!
Do you think the drawings will be fixed when it comes to colours updating and view positions updating. I always have to go to the drawing and click on every view that needs to be updated, change one of the settings and click ok and then change one of the settings back to how I want it, then it updates.
I just switched to bounding box, its quicker to load to the point where the box shows up and I can move it but then once I click to place it down then it hangs forever!!!
its usually on or off depending on what I need but look at this picture, you will see the panel has a grey base but it should be black like it is in most of the other drawings ( associative is on ). However the section view shows that the base is black.
I add a lille issue that i think is connected to the others.
Putting inventor content center library files (.idcl files) on a network path make the model update very slow.
No vault installed, but the need to share customized CC Library.
Moving the same files to a local path make everithing work correclty
Bye
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
The update did fix the issue for us, though with one exception-- if I change to a project with a different material/appearance library location (without re-starting Inventor), it still becomes impossibly slow to place an assembly view.
Sam B
Inventor 2012 Certified Professional
Inventor Professional 2015 SP1 Update 1
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Hi Sam,
Good to hear that you're seeing benefit when working with your initial networked Design Data.
Would you be able to provide me with your actual project ipj files as well as the respective referenced Material/Appearance libraries so that we can reproduce the issue seen when changing projects? That shouldn't be an issue now...(chris.mitchell@autodesk.com)
Chris
I recently installed Inventor 2015 (just Inventor - no Suite) Also installed SP1 and Update 1 for Sp1.
It is still extremly slow in creating views. It gets back to normal when the network cable is unplugged.
Any ideas?
Cheers
Finnur P.
The problem Sam Bixler raised below was due to 2 copies of the same adsklib file being referenced in the 2 ipj files. Inventor doesn't support copying the same adsklib file at the OS level & then loading them both at the same time, (albeit in this case during the interim of changing projects).
Finnur - can you share any details about how you have your Inventor project configured with Design Data, Templates, Libraries, Material/Appearance libraries, network/local data, vault etc ?
Chris
Thanks Chris,
I had already figured out that it had to do with the project file. The customer had an extra library with all the RAL colours and that library was not where the project file said it should be. Problem solved
Thankls
Finnur P.
I used to do what you described. Then a collegue showed me to check the Chain box just above the Design-view List.
No more back and forthing!
@Anonymous wrote:Thank you. lets hope you guys get it sorted. Cant get any work done right now!
