in assembly i use -export to pdf- but a html is created, no pdf. I can't find any options.
Please help, thanks.
Solved by support. Go to Solution.
What happens when you do a "Save copy as" pdf ?
check tools tab, +add-ins button
go to the translators tab and ensure that "Translator: Pdf" is set to automatic/ondemand then verify that the dll file shown in the location section lower down in that dialog box is actually present on your computer.
then maybe try to check the "loaded/unloaded" box and try to create a PDF again.
Also what is in this html file that is being created..
the solution was a option in the new firefox. I don't really know why export to pdf in inventor causes
firefox.
So what, it works now.
Here is the link
