Am I missing something or has this option disappeared? I know for Newbies it could cause confusion but I've always had this turned on when I want to use a Driven Dim in another parameter.
Solved by mrattray. Go to Solution.
Hi!
No, doesn't disappeared so far.
rEBOOT pc and/or inventor
Install service packs.
I actually meant the option to select whether a Driven Dimension is placed or an Error saying the sketch is over constrained? Was in the Application Options on the Sketch tab. Can you send a screen shot of where this options is in IV2015 please?
It's not on the sketch tab, it's in the prompts section. I'll try to get a screen cap for you, but it's a PITA to find.
Rob,
Another option is the Reset Inventor with the Inventor Reset Utility:
Have a Happy Holidays.
Thanks Mike,
Bit confused her too. I'd already said you'd answered my question!
Mike,
When thing unexpectedly go away like this the first place to is changes in their user environment.
The Reset Tool allows it to go back to factory defaults.
This was information that others may want as they look at this forum post for solutions in the future.
Have a great weekend.
