Inventor Forum
Inventor 2015 Open Dialog Freezes as File Type Changes
3 REPLIES 3
osakakt
471 Views, 3 Replies
Open dialog box in Inventor 2015 freezes when I change the file type to be displayed. For instance, if I want to open a STEP file, I would change the "File of Type:" dropdown menu. After selecting the file type, the software freezes. The program becomes unresponsive, 25% usage on CPU, and need to force quit from the task manager. Most of the time, I can get around this by creating a new drawing and drag and drop the model.
Any help is appreciated
3 REPLIES 3
salariua
in reply to: osakakt
Instead of changing the file type in the open dialog jus type * in the File Name above it. It should show all files no matter of the file format. If you then select a file that's importable in Inventor you get the Options active at the bottom next to open.
make sure that it's not on a slow network or that the anti-virus is not interfering.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
johnsonshiue
The behavior does not sound right to me. What Windows version are you on? Have you apply Inventor 2015 SP1? Could you try a few things and see if it makes a difference?
1) Start up Inventor and go to Tools -> Add-Ins -> Translator tab. What is the status of each Translator Add-In?
2) Close Inventor. Right-click on Inventor shortcut -> Run as Admin. Then try the workflow. Does it work?
Thanks!
Software Test Engineer
Cadmanto
Welcome to the forum.
Is anyone else in your department seeing this same issue with the same files?
Does this happen only with imported files, some imported files or all imported files.  Are you seeing this when you change the files type to some inventor file extension (i.e. .ipt to .iam or to .idw only)
Do you have all of the latest SP's and hotfixes loaded?  What are your system specs?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
