Hi to all,
maybe it's only a issue for my version...
In anterior versions:
-when you did a sketch it present perfectly oriented with axis and "orizontal" and "vertical" , up and down for the constraints
-when yiou had a orbited sketch or rotated.. the "Look At" command was perfect to allign it orthogonally and with orizontal and vertical alligned
In 2015 release i have this:
And you?
Admaiora
Solved by -niels-. Go to Solution.
There's a setting in 'Application options > display' at the bottom that changes the look at behavior.
Does changing that have any effect on this?
(changing it to 'align with local coordinate system' did for me)
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Yes!
Thanks Niels!
New option?
Admaiora
Niels van der Veer
The Netherlands
