i've read some articles about that, but there is no solution for me.
I've installed Update2 + Hotfix INV19022, same Problem
I can't deactivate the home screen because i have no chance to open anything because Inventor hangs.
I have
WIN7-64
Inventor Professional 2015
Microsoft Security Essential (deactivated)
Firewall (deactivated)
UAC (off)
I am local Admin
deleted C:\Users\user\AppData\Roaming\Autodesk\Inventor 2015
deleted HKEY_CURRENT_USER\.......\Inventor
I don't know what to do.
Need help.
Greetings
Solved by m.hermann. Go to Solution.
I also tried that:
http://beinginventive.typepad.com/being-inventive/2014/04/inventor-2015-startup-crashes.html
The machine is totally new installed . The problem is with every user.
I found this:
http://forums.autodesk.com/t5/Inventor-General-Discussion/Can-t-use-inventor-2015/m-p/4954220
from ChrisMitchell01
so i was able to deactivate the home screen, hope that user don't activate it again.
But this is a bug in Inventor, Autodesk should fix this soon.
