I'm trying to install a 30 day trial copy of Inventor professional. This is the manually downloaded executable (save to disk) rather than the online streaming installer which also fails.
All firewalls and antivirus software has been turned off before install. However, it appears the installer refuses to see my internet connection.
Any help would be appreciated.
Install log below:
2014/9/14:15:02:52 Administrator GALVATRON === Setup started on GALVATRON by Administrator ===
2014/9/14:15:02:52 Administrator GALVATRON Path_Length: 155
2014/9/14:15:02:52 Administrator GALVATRON Current Directory C:\Users\ADMINJ~1\AppData\Local\Temp\_AIE487.tmp
2014/9/14:15:02:52 Administrator GALVATRON Launch
2014/9/14:15:02:53 Administrator GALVATRON Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINJ~1\AppData\Local\Temp\_AIE487.tmp\Setup\InventorUI.dll
2014/9/14:15:02:53 Administrator GALVATRON Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/9/14:15:02:54 Administrator GALVATRON Install CustomCallback Info Invoking custom callback for details: [VAULT] CB_FUNC=Win7RTMBlockCheck CB_SOURCE=C:\Users\ADMINJ~1\AppData\Local\Temp\_AIE487.tmp\Setup\InventorUI.dll
2014/9/14:15:02:54 Administrator GALVATRON Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/9/14:15:02:54 Administrator GALVATRON Inventorui== Parameter: VCPlatformCheck SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/9/14:15:02:54 Administrator GALVATRON Install CustomCallback Info Invoking custom callback for details: [AUTODESK_RECAP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ADMINJ~1\AppData\Local\Temp\_AIE487.tmp\Setup\InventorUI.dll
2014/9/14:15:02:54 Administrator GALVATRON Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2014/9/14:15:02:54 Administrator GALVATRON Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2014/9/14:15:02:54 Administrator GALVATRON PageOpen LaunchDialog
2014/9/14:15:02:56 Administrator GALVATRON PageOpen LicenseDialog
2014/9/14:15:02:58 Administrator GALVATRON PageOpen ProductInfoDialog
2014/9/14:15:03:05 Administrator GALVATRON PageOpen InventorFlavorSelectionDialog
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==DefaultLanguage: en-us
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==InstallName: INVENTOR
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==ProductName: Autodesk Inventor 2015
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==DisplayName: Autodesk® Inventor® 2015
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==DeploymentName:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==SetupTitle: Autodesk Inventor 2015
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==ConfigTransform:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==ExeParams:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==ProductCode: {7F4DD591-1964-0001-0000-7107D70F3DB4}
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==SupportLink:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==InfotainmentLink:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==MsiFileName: inventor.msi
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==AdminImageConfigName: Imgx64
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==AdminImageRoot:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==GetBaseDeploymentName:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==DeploymentLocation:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==DocumentLink: http://autodesk.com/inventor-install-2015-enu
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==InstallDeploymentShortcut:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==ModifyDeploymentShortcut:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==SetupLockType: 2
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==SetupNetworkType: 1
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==SystemLocale: 1033
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==EvalMsiFilePath: C:\Users\ADMINJ~1\AppData\Local\Temp\_AIE487.tmp\SetupRes\eval.msi
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==EulaPath: C:\Users\ADMINJ~1\AppData\Local\Temp\_AIE487.tmp\EULA
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==InstallLogPath: C:\Users\ADMINJ~1\AppData\Local\Temp\Inventor2015Install.log
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==ConfigFile: C:\Users\ADMINJ~1\AppData\Local\Temp\_AIE487.tmp\Setup.ini
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==SetupPath: C:\Users\ADMINJ~1\AppData\Local\Temp\_AIE487.tmp\
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==NetworkLogPath:
2014/9/14:15:03:05 Administrator GALVATRON Inventorui==SourceRoot: G:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_dlm\
2014/9/14:15:03:07 Administrator GALVATRON Inventorui== Parameter: Page2 Action: SetMsiProperty Item: PRODUCTEDITION Value:INVPROSA
2014/9/14:15:03:07 Administrator GALVATRON PageOpen ProductSelectionDialog2
2014/9/14:15:03:12 Administrator GALVATRON PageOpen FullProgressDialog
2014/9/14:15:03:12 Administrator GALVATRON Installing .NET Framework Runtime 3.5 SP1: "G:\Autodesk\Autodesk_Inventor_2015_English_Win_64bit_R1_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/9/14:15:03:16 Administrator GALVATRON Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
Is Your OS is Windows 8 or 8.1? if yes, please refer to the following link "http://support.microsoft.com/kb/2734782" to solve the .Net Framework 3.5 failed installing on Win8 problem.
based on my experience, the method3 should be work
