Inventor Forum
Inventor 2015: Derived part crash (multiple instances)
18 REPLIES 18
Message 1 of 19
artieaurora
1123 Views, 18 Replies
Several of my derived parts will no longer open.
(I am, however, able to open assembly's that contain the derived part).
anyone else have this issue?
files attached
(70-10247i.ipt is derived from 70-10247.ipt)
Inventor Professional 2015, 64-Bit
Build: 159, Release: 2015 RTM Update 1 - Date: Mon 05/12/2014
Tags (1)
18 REPLIES 18
Message 2 of 19
Desam
in reply to: artieaurora
Inventor crashes every time I open the '___i' part.  I have experienced corupted derived parts in 2015 (and 2014) that could not be recovered but not a crash straight to desktop before.  I have always reported the problem and hopefully Autodesk create fix in next service pack but have had to just bite the bullet and recreate all affected parts each time and cross fingers, frequently backup and hope it doesnt happen again.
regards,
Hugh
Message 3 of 19
artieaurora
in reply to: Desam
As it turns out, it's not only derived parts that are having this problem. It does appear to be isolated to parts that were imported from other CAD packages.
(not all imported parts have this issue)
crashes to desktop, no option or error reporting.
Message 4 of 19
johnsonshiue
Hi! The behavior is not normal. Did you submit crash report when it happened? If yes, could you send me an email (johnson.shiue@autodesk.com)? I need to look into the report and see where the problem is.
Thanks!
Software Test Engineer
Message 5 of 19
johnsonshiue
in reply to: Desam
Hi! Did you have reproducible corruption cases? If yes, did you report to anybody at Autodesk? Could you send me the detail of your prior reports? I would like to understand the situation better and make sure all options had been exhausted.
Thanks!
Message 6 of 19
artieaurora
in reply to: johnsonshiue
Inventor does not generate a crash report.
I have 100's of files like this. Needless to say, this is a disaster.
I sent files (13MB) to your email. Let me know if you received.
Message 7 of 19
Yijiang.Cai
I can reproduce this crash in R2015 + Update1without CER dialog when loading the attached derived part, but not reproducible on latest R2015 SP1 internal build. Please have a try when SP1 build is released.
River Cai
Inventor Quality Assurance Team
Email: River-Yijiang.Cai@autodesk.com
Message 8 of 19
artieaurora
When will SP1 be available?
Message 9 of 19
SP1 is planned for mid-September.
How many others are seeing similar crashing without the ability to submit a CER ?
Chris
Chris Mitchell
PDMS Customer Engagment Team
Message 10 of 19
we have at least seven users here that have the problem.
Message 11 of 19
This is under investigation to see if it can be hot-fixed prior to SP1.
Sorry for the inconvenience,
Chris
Chris Mitchell
Message 12 of 19
david.harris
In our continuing efforts to provide high quality products, Autodesk has released Hotfix INV19022 which addresses this issue.
We thank all our customers who identified these issues and reported them to us. These reports give us the opportunity to improve the product and provide you with the best solution in mechanical design. We also thank you for your continued business and for feedback regarding the content of this update release.
Respectfully,
Autodesk Inventor Product Team
Message 13 of 19
artieaurora
in reply to: david.harris
error message when trying to install hotfix.
Message 14 of 19
artieaurora
Fixed.
Installed Update 2.
Installed Hotfix.
everything is now ok.
thanks
Message 15 of 19
eric.paris
I have the same problem with Update 2 installed.
Message 16 of 19
johnsonshiue
in reply to: eric.paris
Hi! The crash you are encountering might be a different issue. Did you send in crash reports? If yes, could you send me an email? I would like to follow up with your separately.
Many thanks!
Message 17 of 19
eric.paris
I don't have a CER Report just the Windows message when an application crash.
I have already an autodesk support case for this problem, i'll keep you inform.
Thanks!
Message 18 of 19
johnsonshiue
Could you tell me the Case ID?
Thanks!
Message 19 of 19
eric.paris
Sorry, my bad, the HOTFIX Hotfix INV19022 did the trick and solved the problem.
I though it was the update 2.
Sorry, and thanks for the hotfix.
