Greetings,
My understanding is an inseperable assembly within another assembly will not promote its children when expoting BOMs. This is not how my installation is behvaing, however. I have also tried selecting purchased rather than inseperable, but it does not change this.
It has been a couple years since I have worked with this, but has something changed in recent versions? A new setting perhaps? Or am I just confused?
Chris Mann
SELEE Corporation
Solved by mcgyvr. Go to Solution.
Not exactly sure what your problem is..
maybe some of the descriptions/characteristics from here will help.
All I can say is use insep/purc/phantom as you would in the real world.
Inseperable is mostly for weldments/riveted/glued subs.. Is that what you have..
Or what exactly are you trying to do?
I went back and read the descriptions of the BOM types and I was mixing up the two types. It is clear I was using parts only for this type work in the past, but I had forgotten.
Thanks for pointing me to the solution!
