Inventor Forum
Inventor 2014
32 REPLIES 32
Message 1 of 33
652 Views, 32 Replies
Inventor 2014
Hi Guys!
Im new to all of this so if anybody could help me out that would be great! I recently go Inventor 2014 and dont fully understand to use it yet. I have lots of knowlage of AutoCAD but not inventor. My problem is whenever i draw a sketch and try to add it to an assembly, this message pops up.
The assebly could not be saved because a different level of detail representation is being edited. Please close all other level of detail representaions to continue with edits.
This pops when i go to use the frame editor. it also pops up when i go to use the miter tool. if someone could help me out it would be greatly appriciated!
Thank you!
32 REPLIES 32
Message 2 of 33
JDMather
You generally add components to assemblies not sketches (although for Frame Generator the component (part) might only contain sketch(s).
I recommend you start here
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
And then attach assembly/part files here that exhibit any problems you experience so that someone can help you using your actual files.
Message 3 of 33
in reply to: JDMather
Thankyou! I really apriciate it. This will help me out a LOT! Thanks a million!
Message 4 of 33
Thanks for everything but i still dont understand what i need to do to get rid of that message. If you could tell we that would be great.
Message 5 of 33
Thanks for everything but i still dont understand what i need to do to get rid of that message. Thanks
Message 6 of 33
JDMather
Message 7 of 33
This is the file.
Message 8 of 33
JDMather
I don't know what you are doing that causes that message, but first thing I noticed is that your sketch has an unconstrained line at the top and it would be better to make use of smmetry about the origin.
Message 9 of 33
LT.Rusty
That's just a single part file.  We need the assembly file (.iam), plus all of the part files (.ipt) that make up the assembly.
At a guess, though, I'd say that you accidentally (and probably without realizing it) created some levels of detail in your assembly, probably by suppressing a component.  Working with LOD's is ... annoying.
Rusty
Message 10 of 33
in reply to: LT.Rusty
Thats the onlything in the assembly. when i try to extrude it it says I can't.The LOD is set to master. i never tuched that
Message 11 of 33
LT.Rusty
Save the assembly file and attach it here as well.
Rusty
Message 12 of 33
LT.Rusty
Okay, waitaminute.  I just noticed something here.
Are you trying to extrude this profile IN THE ASSEMBLY?  Or are you trying to extrude it IN THE PART?
It's a closed profile, it extrudes just fine in the part.  Assembly extrusions have to be done from a sketch in the assembly, not from a sketch in the part.  Also, they can't add material - you can only remove material in  operations done at the assembly level.  If you're trying to do an extrude-cut in the assembly and you're trying to use a sketch that's in a part, then yes - it's going to fail.  If you're trying to do an extrude-cut at the assembly level and you have no actual solids in your part, then it's also going to fail because there's no geometry to change.
Rusty
Message 13 of 33
It won't even let me extrude this 40'' by 50" rectangle.
Message 14 of 33
Then how do i do it?
Message 15 of 33
LT.Rusty
I just opened the part file, clicked on EXTRUDE, and there you have it.  See the picture below.
You have to be working in the part though, not the assembly.
Now speaking of assemblies ... in order to figure out your issue with the Level of Detail error, I need your assembly file.
Rusty
Message 16 of 33
After I click finish sketch, I go to extrude it and it tells me that this file can not be eddited
Message 17 of 33
LT.Rusty
Did you somehow set it to be read only?  Take screenshots of the error messages you're getting and attach them here.  Also, attach your assembly file please.
Rusty
Message 18 of 33
don't know how to take a screen shot.
Message 19 of 33
LT.Rusty
Start button --> ALL PROGRAMS --> ACCESSORIES --> SNIPPING TOOL
Save your snips, then use the button in the text editor here (it looks like a little photo of a tree) and post them here.
Rusty
Message 20 of 33
