Inventor General Discussion
New Member
fenerichi
Message 1 of 6 (696 Views)
Inventor 2014 Wish List?
696 Views, 5 Replies
01-07-2013 08:10 AM
For next releases:
1 - Editing sketches dimension just clicking on feature, like SW.
2 - Show the entities information without having to search for the information, like SW
3 - Ability to insert constraint just selecting the entities and software knows what you want, like SW.
4 - Change the view drawing even after inserted on sheet, is very usefull. Ex: You inserted a front view but you want to change it to top view. So you must delete the view and choose another one.
5 - Width mating parts.. it MUST have on assembly environment.
6 - Improve or complete change the 3D sketch. SW have one of the best, simple and full controlled 3d sketches of ever. Please, call them and ask how they do it.
Well, this is just a lew wish list.
Marcos Fenerichi
Ullian Sheet Metal Doors and Windows - Brazil
Inventor Professional 2013 SP 1.1 - 64-bit
Dell Precision T3500
HI fenerichi,
The best place to post wish list items these days is the Inventor IdeaStation.
You can use this link to share your ideas about how to improve Inventor with the Development Team, and others will show their support for your idea by giving it kudos.
I hope this helps.
Curtis
pball
Message 2 of 6 (684 Views)
Re: Inventor 2014 Wish List?
01-07-2013 08:33 AM in reply to: fenerichi
Just so you know there is a thread with quite a few wishes already.
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2014-Wish-List/m-p/3482732/highlight/true#M...
Curtis_Waguespack
Message 3 of 6 (679 Views)
01-07-2013 08:38 AM in reply to: fenerichi
HI fenerichi,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Pro
ampster
Message 4 of 6 (653 Views)
01-07-2013 10:31 AM in reply to: fenerichi
and you may as well start or go with a 2015 wish list as I am sure 2014 is not going to be changed or added to at this point.
*Pro
sbixler
Message 5 of 6 (641 Views)
01-07-2013 11:08 AM in reply to: fenerichi
In regards to this one, Inventor is way past this-- before about 2011, double clicking on a feature would show all sketches and other dimensions associated with the feature, available for editing.  Now you just use the right mouse button and choose "Show Dimensions".  Change dimensions as you wish, then hit the 'Update' button.  Still very useful, just not quite as easy to get to as it used to be.
New Member
fenerichi
Message 6 of 6 (553 Views)
01-15-2013 06:07 PM in reply to: sbixler
Thanks you for the tip. It seems to be very useful. However, editing sketch dimensions on SW we don't need go to the browser we just click on the feature on the screen and all dimensions appears. Then we just drag the blue sphere and changes are done. Even so I thanks you. It will help a lot. -- Marcos Fenerichi
