Hey guys! I was working on my inventor file and i went to enviroments to enter the tube and pipe section. When i did so, multiple times, the program would start loading and in the bottom right hand corner it says "Executing Create Pipe Run" then the the creen freezes up. I then restarted the inventor and tried again, multiple times, as i said before. If somebody could please help me that would be great!
Thomas
Where is your design data located? Go to Manage / Project and if it's default then check Tools / Options / Files
Do you have an assembly there called piping runs.iam?
Design Data\Tube & Pipe\en-US\piping runs.iam
Make sure you are under correct project and all libraries attached.
Hi! I have heard similar behavior from some on 2014 particularly. The behavior is not reproducible on 2015. So far we are investigating the cause and possibly finding a fix. In the meantime, you could try adding the system variable on your machine and it should allow you to enter T&P environment.
Close Inventor.
Control Panel -> System -> Advanced System Settings -> add System Variable.
Create a system variable called "DYNAMIC_LOAD_APPLETS" without quotes and set the value to 0 -> Apply -> OK.
Restart Inventor.
It should resolve the problem. I am sorry for the trouble.
Many thanks!
