Solved by CCarreiras. Go to Solution.
Hi!
Yes, inventor 2015 will open your files made in previous versions.
When you save the file in Inventor 2015 the files will be migrated to the new version.
From here, you can not open again in previous versions.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
