Inventor Forum
Inventor 2014 takes too long to think placing a constrain
9 REPLIES 9
Message 1 of 10
Hfrossard
928 Views, 9 Replies
I have been running Inventor 2014 on my machine for a while now. I don't know what is happening, but it takes about 5 minutes to think about a constrain placement.
It was not happenning before, I think some kind of update triggered this.
What should I do?
Inventor diagnostics says:
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
NVIDIA GeForce GTX 650
AIRViz Device Manager \ VirtualDeviceDx11
Feature Level 5_0
Performance Mode
Optimized Software Renderer
Graphics driver file nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um is version 9.18.13.3523
Current optimization settings are not known
The display is using 32-bit color
Inventor Version:
Build: 222, Release: 2014 SP1 Update 3 - Date: Mon 02/10/2014
64-Bit Edition - 131072.00 GB
Loaded Inventor Add-Ins:
Assembly Bonus Tools
Simulation: Dynamic Simulation
Simulation: Frame Analysis
iCopy
System Information:
Operating System: 64-bit Microsoft Windows 8.1 Single Language (Build 9200)
Language: Portuguese
System Manufacturer: LENOVO
System Model: 90A3A7P
BIOS: F1KT51AUS
Processor: Intel(R) Core(TM) i7-3770S CPU @ 3.10GHz (1 processor, 4 physical cores, 8 logical cores)
System Memory: 7,957 GB RAM
Graphics Device Information:
Renderer: SW
Manufacturer: NVIDIA
Chip Type: GeForce GTX 650
DAC Type: Integrated RAMDAC
Graphics HW Memory: 966 MB
Display Mode: 1920 x 1080 (32 bit) (60 Hz)
Graphics driver file: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver file version: 9.18.13.3523
Driver Date: 4 March 2014 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description: NVIDIA GeForce GTX 650
Vendor ID string: 0x000010de
Device ID string: 0x00000fc6
VendorID: 10de
DeviceID: fc6
SubSystemID: 129119da
Revision: a1
Direct3D 10 / DXGI System Information:
Dedicated Video Memory: 966 MB
Dedicated System Memory: 0 MB
Shared System Memory: 3,000 GB
DxDiag System Information:
Operating System: Windows 8.1 Single Language 64-bit (6.2, Build 9200) (9600.winblue_gdr.140305-1710)
Language: Portuguese (Regional Setting: Portuguese)
BIOS: F1KT51AUS
Processor: Intel(R) Core(TM) i7-3770S CPU @ 3.10GHz (8 CPUs), ~3.1GHz
System Memory: 8192MB RAM
Page File: 5964MB used, 3463MB available
DirectX Version: DirectX 11
DxDiag Version: 6.03.9600.16384
DxDiag Graphics Device Information:
DirectX Version: 11.0
DDI Version: 11
DDI Version Number: b
DxDiag WHQL Level: 0
Driver Signed Valid: True
Driver Signed: True
Revision:
Graphics HW Memory: 4037 MB
Display Mode: 1920 x 1080 (32 bit) (60Hz)
Driver file version: 9.18.0013.3523
Driver Date: 3/4/2014 11:35:23
WHQL Level: 1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: Hfrossard
My guess is that you have something wrong with one of your parts or with one of you existing assembly constraints.
Are you using Adaptivity?
Can you attach your assembly here?
Message 3 of 10
Hfrossard
in reply to: JDMather
Unfortunatelly I cannot post the assembly due to product secrecy agreement.
There is no adaptivity.
It may be some constrain problem. I have a big assembly with lots of sub-assemblies.
Message 4 of 10
howardlee306
Check to see if constrain failure redundancy analysis got turned on during the update.
Message 5 of 10
blair
Inventor does have a "Show Sick Constraints" tool. It's in the Assembly Tab under Relationships.
Delta Tau Chi ΔΤΧ
Message 6 of 10
Hfrossard
Thank you for the replies.
The redudancy check was on. I turned it off, it made the constrain placement a little bit faster, but it is still taking a lot of time.
The "show shick constrain" button is grey, so there is no bad constrain anymore, I think.
A new problem is that, from time to time, some sketches (used to build the parts) started crashing and losing their references. In most of them, if I redefine the face to the same face it was drawn on in the first place, it works.
Message 7 of 10
Mario428
That would be adaptivity of some form and would cause a big assembly to slow way down, especially if those sketches kee losing their references.
Message 8 of 10
Hfrossard
in reply to: Mario428
What is the best way to find and resolve these adaptivity issues?
Message 9 of 10
blair
I try and clear Adaptivity as soon as possibly in a design. It will require going back in to sub assemblies and applying additional constraints once the Adaptivity is cleared. No really "Easy Button" to fix it. Having a number of items "Adaptive" will slow down the fastest of systems.
Delta Tau Chi ΔΤΧ
Message 10 of 10
Hfrossard
in reply to: blair
Thank you very much. Now I see that there are a lot of adaptive parts. I am clearying all up.
